| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#6411 |
#6412 | |
The mod can not be performed if LC78601 was soldered. You need to perform the mod before soldering this chip. First you need to cut the trace between pin 40 and pin 22 as per top_modification.jpg - left picture. Than, turn the board on bottom and perform the modification as per bottom_modification - right picture. Instead L7 put a 1K2 resistor or a 2K potentiometer to get your preferred contrast and make a strap between two pads. The strap will bring back Vcc to pin 22. That´s all. Regards, Tibi Last edited by tvicol; 1st November 2012 at 07:28 AM. |
#6413 |
Dimitris
Tibi do the assembled kits include this mod?
#6414 |
Not yet, but I plan to do so.
Regards, Tibi |
#6415 |
#6416 |
Ok, I found another solution who will work for everybody.
All modifications are only on the same side of the board, so no need to do prior mounting LC78601 and the mod can be applied to existing Shiga´s as well. Cut near C60 as in attached picture. You may need to unsolder C60. This will separate power supply pin 22 from pin 40. Replace L7 with an 1K2 resistor and strap two pads in order to power back pin 22. That´s all. Regards, Tibi Last edited by tvicol; 1st November 2012 at 11:22 AM. |
#6417 |
I read a lot here about the cd platform with a puck.
Have you already thought about a 3d printer? Have no idea how accurate these printers are but it is perhaps an option. Regards, Rudy
It’s not what you know, but who you know “and where they are” |
#6418 |
Dimitris
The DIY cheap 3d printers are really really rough at their output. The result would be really unbalanced and asymmetrical out of the printer.
A better option would be a CNC or laser cutter |
#6419 |
I mean of course a professional 3d printer and create the cd platform and the puck by a company that have a professional 3d printer.
The cabinet can also be made with a 3d printer ![]() Regards, Rudy
#6420 | |
Everything is ok now. I was using a other strip from 'kotobo' to connet the laser-mechanic. Now I am using yours and now the shiga plays all my CD's very well, without even 1 scratch. Super ! And the sound is sublime. I use on the output a buffer stage with 74hc04 and a AudioNote transformer. Audio Note Tibi, much thanks for such good work ! |
