Finally, an affordable CD Transport: the Shigaclone story - Page 641 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th October 2012, 07:35 AM   #6401
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Originally Posted by dimkasta View Post
Youhoooooo I m the only one red... I m special
It's just a reminder to me to do not forget the CD. Your goods will be delivered Monday as well.
Tibi
Vicol Audio
Old 30th October 2012, 11:10 AM   #6402
Finally more or less finished, and sounding good
Old 30th October 2012, 11:15 AM   #6403
Old 30th October 2012, 11:33 AM   #6404
My main problems where all my own doing. nothing as obvious as bad solder joint or wrong value components.
First big problem was cause by testing on a damp piece of wood wich caused all kinds of problems. Frankly very silly on my part.
Second problem the puck I was using was recovered from a 15 year old boombox it had so much play in it that sometime it worked and sometimes it did'nt. changed the motor spindle to one with 3 ball(no puck) and all is good
I placed the transformer in another box, really dont like transformers near anything else.
I tried to figure out the lcd saturation thing but as far as I can tell all the relevant traces are under the LC chip so unless somebody can enlighten me I'm just gonna have to live with it as is.
Old CD most of mine are over 15 years old tend to have issues mainly scratches which cause skips one CD would not even read TOC it had wierd mould under the plastic.
New CD will play from start to finish perfectly.
Old 30th October 2012, 02:56 PM   #6405
TheGimp is offline TheGimp  United States
TheGimp's Avatar
blueworm, good to see you got it going.
Here is a pix of where to cut. Be careful and use a sharp pointed X-acto (Razor knife/scalpel...).
The trace is very short. The via is to power. Put the resistor from the via to the pin and don't add a cap.
Old 30th October 2012, 04:37 PM   #6406
lucylu is offline lucylu  England
Hi Tibi Received all my parts today ,very well packed,thank you and your team for all this,bet you are glad its nearly all over cheers regards john
Old 31st October 2012, 03:37 AM   #6407
^^TheGimp. Thanks for explaining how to do that
Old 31st October 2012, 03:47 AM   #6408
Default chassis info
blueworm can you provide the source for your chassis? looks really nice
Old 31st October 2012, 03:53 AM   #6409
Old 31st October 2012, 10:07 AM   #6410
Easy question, with nice awnser for those on the other side of pond.
The case is from Par Metal, New Jersey. Series 20.
Par-Metal
Copyright 1999-2017 diyAudio
