Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th October 2012, 08:43 PM   #6341
Hi TheGimp,
I'm pretty much at the same place as you, except that I broke a leg off of the laser transistor Q2 IIRC, and I'm still waiting for replacement.
In the mean time I reflowed all solder joints on passives and once I had done that I actually did as suggested by danzup and re-soldered all IC's.
I have also sourced another mechanism (puck less).
Where did you source your components? do you have the mouser crystal? what loading's have you tried? data sheet for this crystal says (need to specify requirement). So far I have tried 8pF and 18pF also tried no crystal for comparison resulting in no TOC read.
Once replacement transistor arrives I will resume testing where I had left off.
Things I am going to try:
1. alternative mech
2. proper crystal CSA-309 8pf loading
3. wait for someone cleverer than me to give awnser.
Please keep us posted on your progress, good look troubleshooting.
Old 13th October 2012, 09:13 PM   #6342
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I built the Full Shiga Kit, so I should have all the correct components.
My second unit I'm building from a pwb set and the SS devices and supplying my own resistors, capacitors, etc.
My concern is I may have miss-placed capacitors which could effect timing.
I'll start looking at signals next I guess.
Old 14th October 2012, 11:24 AM   #6343
danzup is offline danzup  Romania
danzup's Avatar
@ The Gimp and @ Blueworm :
this week someone (I prefer not to say names) assembled a Shiga from Vicol audio . After assembly he observ that his shiga behave exactly as your unit.Then he bring this to me.
After checking the resistors ,visual that are in value and place correctly and hope that capacitors are correctly mounted, as I was not eager to desolder and measure every each of capacitor, I began to solder each component and also all IC on that board .
After that, testing : work like charm and as intended !!!
So after soldering over 15 piece of Shiga (wich all fired up and working from the first time ) and debuging another unit wich after my "touch" began to work ,I have only one advice for you : magnifier and eyes can lie to you , just solder with big blob of solder every smd component and watch for short circuit !!!!
P.S.: both if you cannot made this kit working contact me on pm and if you pay for delivery to me and back I will debug for free your board .
There are not better tube than 6P3S and 6N2P for my ears !
Old 14th October 2012, 11:39 AM   #6344
Thank you danzup for the wonderfull offer, its nice to have a safety net. As I mentioned in my earlier post I resoldered all passives and contrary to my earlier comment I did go ahead and resolder all IC also. Now awaiting spare Q2 to continue testing. Elf honor is at stake! (Ben and holly's little kingdom).
Old 14th October 2012, 03:49 PM   #6345
TheGimp's Avatar
Thank you for your offer danzup. Hopefully I will be able to resolve the problem myself but it is good to know I have the option of your offer.
I'm going to print out a large copy of the schematic and go through the data sheets to analyze each component for critical value positions.
Resistor values have already been confirmed, so they will be visually inspected again using a 10X stereoscope at a SMT solder station.
During soldering, I was able to observe solder wicking under each IC pin to pad junction so I believe the connections are good, but will re-solder them as that is easy to do.
Wrong value bypass caps for instance should not cause this problem, but electrolytics are easy to evaluate and change.
100nF bypass caps can not be evaluated on board, but can be ignored on a first pass.
I suspect a wrong value/poor solder connection at an RC filter causing a time constant to be wrong. I tried measuring capacitors on board, but got erratic readings. Some were wildly off and I suspect this was due to circuit loading.
I would really like to identify the exact component (or at least sub-circuit) responsible for this behavior, so that we can document it in the case others have the same issue, since it appears that at least three boards have exhibited this problem.
If my second board functions when complete I'll have a reference to compare to, but it will take several weeks before I finish it.
I thought about doing a matrix of static voltages but I suspect that would not be very useful.
Timing is going to be difficult to analyze since this is a start-up issue.
Back to visual inspection and re-soldering.
Old 14th October 2012, 04:01 PM   #6346
Tibi: when are you expecting to send out the fully assembled kits? Maybe you've said this already, sorry if I've missed it...
Fran
Old 14th October 2012, 04:44 PM   #6347
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Yahoo to tvicol Send a message via Skype™ to tvicol
Fran
Hi Fran,
I already started.
I don't want to promise, but I'm doing my best to have GB closed this month.
Tibi
Old 14th October 2012, 05:05 PM   #6348
TheGimp's Avatar
Top and bottom views.
Old 14th October 2012, 05:15 PM   #6349
danzup's Avatar
R19 R28 R27 R19 R8 R9 R38 R31 R13 R15 are not ok ( on solder ) as seen in your photo !
Please use more solder and flux on all resistors an capacitors.
If i want to take a guess about the subsystem that do not work ,it is about resistors and capacitors near the LA9242 or resistors and capacitors that take signal from LA and routing to LC .
Old 14th October 2012, 05:28 PM   #6350
tvicol's Avatar
TheGimp,
I had a close look on your board.
R1 and R17 must be 27K while on your boards looks like you have 43ohm, but the image is not very clear.
However, I'm sure that these resistors are not from the kit I sent to you.
Also, please check soldering for C16, R19 and R5.
Tibi
Copyright ©1999-2013 diyAudio
