Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 4th October 2012, 11:11 PM   #6331
tonyptony is offline tonyptony  United States
Originally Posted by tvicol View Post
Tsuyoshi Yamamoto - Autumn in Seattle CD
Tsuyoshi Yamamoto - Autumn in Seattle CD Album
A great group. I have a few of their CDs. I didn't get this one because IMO a lot of the standards on the disc are really not that great.
Old 6th October 2012, 09:11 AM   #6332
woodturner-fran is offline woodturner-fran  Ireland
Looking good tibi - I'm looking forward to getting mine set up and running. My plan is to house it with my euvl dac with joachim gerhard filter buffer all running off battery/shunt supplies.
Fran
Old 7th October 2012, 03:42 AM   #6333
twwyt is offline twwyt  Australia
I've just spent the last couple of days looking through this thread and must say I am very impressed with the results people have achieved.
I can't figure out exactly what tvicol is offering everyone however. From what i can see it is a redesigned controller board for the cd mech, is that correct?
Also, is it possible to purchase just the pcb for the mech + the lcd display?
Old 7th October 2012, 10:30 AM   #6334
Please ignore my last post, I found the post with pricing and options etc. This certainly looks like a great option at a fantastic price-point.
Old 8th October 2012, 08:41 AM   #6335
Ivo-Cici is offline Ivo-Cici  Macedonia
Ivo-Cici's Avatar
Send a message via MSN to Ivo-Cici Finally, an affordable CD Transport: the Shigaclone story
Hi Shigaclon People
tonyptony a few pages ago make a good propound to migrate on
//www.diyaudio.com/forums/digital-source/217177-using-new-2012-shigaclone-create-killer-high-end-transport.html
In that way I thing we accent the great job of tvicol.
Also ease way to make compare JVC EZ31 and new made board.
Do you???
Old 8th October 2012, 12:57 PM   #6336
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Tibi,
Despite the best efforts of the postal services (package busted open on both ends), the package arrived with all components intact and unbroken. Good job of packing.
The boards look great!
Thanks again to all who helped with this project.
Steven
Old 11th October 2012, 09:11 AM   #6337
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
...IŽll send you a copy with the kit...
I appreciate it thanks
Old 11th October 2012, 02:18 PM   #6338
TheGimp's Avatar
I tore apart a couple of CD-rom drives, and two junk boom boxes (one free the other $5 ad a thrift store).
Here is a pix of the pucks. The CD-Rom drives all used small diameter pucks with magnets that measured less than 1cm in diameter. Despite the size, they were quite strong and able to lift the counterpart from as much as 1cm distance. Regrettably, the shaft diameter on teh CD-Rom drives is larger than the diameter on our transports so the complete puck assembly will not transfer.
The boom boxes used much larger pucks. One boombox used a 15 pin version of the transport which is almost identical to the one we are using. It is so close, I am able to use the puck (leftmost in pix) and the plastic laser shield from it's transport on the transport I got with my complete kit.
This chuck has a pad on the bottom to help prevent the CD from slipping.
The boom box also provided several connectors, a split bobbin shielded power transformer, rubber shock mounts for the transport and other useful components.
Old 13th October 2012, 05:10 PM   #6339
TheGimp's Avatar
blueworm, did you ever resolve your problem?
My unit does essentially the same thing.
Power up with door switch open, unit spins with "00" display.
Place CD and puck in place, switch door switch closed, unit goes to blinking "- -" 11 times during which the platter spins, sled seeks and laser focus operates, then it goes to "00" .
Laser is functioning as verified with a camera with no CD in place.
No front panel switches cause any operation of the unit.
LCD contrast is poor and one has to look at a shallow angle to see the difference between active and inactive segments.
I installed a pot for the LED intensity and it helps a little.
How do I adjust contrast?
My unit was assembled on a SMT workstation, then cleaned and inspected for solder faults under a stereo microscope. None present.
Resistor placement was verified for both my boards (second still missing connectors, etc) by measuring the components on the board.
Old 13th October 2012, 06:08 PM   #6340
TheGimp's Avatar
As an added note, I watched the transport and noticed that the tracking mechanism was performing a lot of tracking adjustment, so I swapped transport to another I had. The first unit had over one tooth variance in tracking. The second almost none.
I still get the same results, so I think I can rule out the transport as the problem.
Yes, I re-applied the solder short for the LASER of the first transport before disconnecting it, and removed the short from the second transport after wiring it up.
Pre-Regulator output is 8.02V
V1 = 5.01V
V2 = 5.01V
V3 = 5.02V
V4 = 5.02V
TP1 = 2.55V
TP2=4.74V
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
