Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 1st October 2012, 07:46 PM   #6311
blueworm is offline blueworm  Spain
Hi everyone, I managed to find some time to put together the shigaclone.
But I cant get it to work snif ...
power supply is fine 8v dc.
All the V1 thru V4 are 5v.
All IC are oriented according to the silk screen and solder joints have been inspected several times with 10X jewelers loupe.
I know I screwed up 3 things.
1. powered up with mechanism laser short in place.
2. powered up with inverted motor spindle/sled/limit switch connector.
3. powered up with inverted lcd connector (18pin thing).
What does it do?
when powered up the disk spins and searches the disk the lcd display shows "--"
once complete the lcd display shows "00" but will accept no more inputs only the TOC button works repeating the read cycle.
I will post some pictures soon.
Old 2nd October 2012, 12:12 AM   #6312
woodturner-fran is offline woodturner-fran  Ireland
First up - I can't see your pics...
I've seen this problem a couple of times with some of the shigas I've built. It has always been a problem with the crystal (or reclock circuit). In one case I replaced the citizen crystal with another one, another I had to clean up the pad a little better to solder it on, and in the 3rd case my own clumsiness killed one of the 74ACT14/74AS74 chips in the reclock circuit.
Based on that and my poor understanding of how it all works I can only suggest looking at the crystal, its power supply, connections etc etc.
Maybe tibi can supply more/better suggestions...
Fingers crossed for you.
Fran
Old 2nd October 2012, 02:54 AM   #6313
Click the image to open in full size. Uploaded with ImageShack.us Thanks woodturner-fran, will try the crystal since I have one laying about, I'm inclined to believe at present that I fryed the LC78601 by inverting its cable. Click the image to open in full size. Uploaded with ImageShack.us Click the image to open in full size. Uploaded with ImageShack.us Click the image to open in full size. Uploaded with ImageShack.us Click the image to open in full size. Uploaded with ImageShack.us
Old 2nd October 2012, 07:23 AM   #6314
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
blueworm,
If you are not using Citizen cristal, load your cristal up to datasheet specifications.
In our full kit we provide Citizen CSA-309, therefore C57 and C58 are 8 pF.
The transport will not take any further commands until the TOC is read.
Tibi
Vicol Audio
Old 2nd October 2012, 07:40 AM   #6315
Tibi,
My crystal is the Mouser BOM one not the recomender CSA-309.
Ok will play around with the crystal and loading will report back ASAP.
Thank you.
Old 2nd October 2012, 07:43 AM   #6316
I seem to remember Peter Daniels acheived the loading using some twisted pair wire ... if its only a few pF that might do for testing purposes.
Old 2nd October 2012, 07:44 AM   #6317
tvicol's Avatar
If is Mouser part than C57 and C58 are 18pF.
See also crystal datasheet.
Mouser Part #: 695-HC49US-169-U
Manufacturer Part #: HC49US-16.9344MABJ-UB
Manufacturer: Citizen
Description: Crystals 16.9344MHz 18pF
Over each cap add one more 10pF or at least one more 8pF.
Also have a look with a camera or phone on the laser (not direct eye) to see if is working.
Tibi
Vicol Audio
Old 2nd October 2012, 09:09 AM   #6318
Tibi,
I recall one of your test videos the laser can be seen quite clearly.
Here is a video I shot yesterday: shiga laser test - YouTube
and another: shiga laser test 2 - YouTube
Old 2nd October 2012, 11:08 AM   #6319
tvicol's Avatar
Originally Posted by blueworm View Post
Tibi,
Looks like your laser is not working.
Check also Q1 and measure collector current while operation.
Tibi
Vicol Audio
Old 2nd October 2012, 01:43 PM   #6320
Just got done testing Q1 collector 42.1 mA with disk spinning and 2.5mA at idle.
Measured voltages also: whilst spinning. E. 4.58v C. 1.83v B. 3.84v
Click the image to open in full size. Uploaded with ImageShack.us Just stacked the 10pFcaps on C57 C58 at least that should be ok now. Click the image to open in full size. Uploaded with ImageShack.us Laser still does not seem to work.
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
