Finally, an affordable CD Transport: the Shigaclone story - Page 624 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th August 2012, 06:19 PM   #6231
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Sean,
We are still working on the remote and CD puck.
AES/EBU, S/PDIF, Toslink and AT&T ST glass is an option to consider, but first we need to have all pieces of this project in place.
As you can see, sourcing of components is a pain. Making custom components is another pain.
Im sure that getting a decent ST glass, at a normal price, will be another challenge.
Tibi
Vicol Audio
Old 28th August 2012, 01:22 AM   #6232
GSI is offline GSI  Europe
Originally Posted by uncle_leon View Post
The datasheet for LC78601 doesn't state this, but the digital output impedance is most likely 75Ohm, as per S/PDIF standard. Did you try the 75Ohm Pi-pad I suggested earlier? I built one with my hand-made resistors (which were accurate to +/-0.1R), and I found it to sound far superior to the original L-pad (the detail and resolution took a leap, in particular). I have not tried any further combinations because I assumed 75Ohm should be optimal... But of course, I will be the first to admit that in the audio world theory and practise are often two different stories.
Datasheet states 12mA output current for DOUT, so loading it with 75 ohm is very bad practice. Minimum load impedance is 390 ohm or more.
Old 28th August 2012, 09:17 AM   #6233
uncle_leon's Avatar
What would you suggest then, GSI? A Pi-pad with 390 Ohm input impedance and 75 Ohm output impedance?
My 75 Ohm In - 75 Ohm Out Pi-pad certainly sounds better than the 390 Ohm L-pad - however bad practise it may be
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 28th August 2012, 09:54 AM   #6234
danzup is offline danzup  Romania
danzup's Avatar
It is like this : 2 resistor of 75 ohm in series so the output of IC see 150ohm , only the DAC see 75 ohm on coax .
Look at schematics , Pi attenuator means simple a divisor for output signal.
There are not better tube than 6P3S and 6N2P for my ears !
Old 28th August 2012, 08:36 PM   #6235
IndyAudi's Avatar
Tibi,
I don't mean to rock the boat but could I possibly drop those 3 CD SFP 10-16 pin mechanisms before I pay my invoice ?
I have plenty.
Danny
paypal artioneer
Old 29th August 2012, 03:23 PM   #6236
tvicol's Avatar
Originally Posted by IndyAudi View Post
Tibi,
I have plenty.
Danny
paypal artioneer
No problem. I'll cancel your invoice and send another one withput mecanics.Regards,Tibi
Vicol Audio
Old 29th August 2012, 04:11 PM   #6237
tvicol's Avatar
Danny,
Just checked your invoice, You have been invoiced only for 3 PCB boards and 3 ICs set.
This is what you have ordered, this is what Im invoicing you.
If you want to build shiga, you will need original transistors and LCD display as well.
Tibi
Vicol Audio
Old 29th August 2012, 04:51 PM   #6238
IndyAudi's Avatar
Hi Tibi,
Could you invoice me please for 3 sets of original transistors and 3 LCD displays also - sorry for any misunderstanding .
Danny
Here's a copy of the paypal invoice.
Date Description Quantity Unit price Amount
31/7/2012 Shigaclone PCB set - This include PCB; CD mechanic SFP101N-16P; chipset LA9242M, LC78601RE, LA6541, transistor set 2SA608NF, 2SB764E, 2SA1342; custom multiplexed LCD. x 3 18.00 54.00
31/7/2012 LA9242M; LC78601RE; LA6541 x 3 7.70 23.10
Old 29th August 2012, 05:29 PM   #6239
tvicol's Avatar
Hi Tibi,
Danny
31/7/2012 Shigaclone PCB set - This include PCB; CD mechanic SFP101N-16P; chipset LA9242M, LC78601RE, LA6541, transistor set 2SA608NF, 2SB764E, 2SA1342; custom multiplexed LCD. x 3 €18.00 €54.00
31/7/2012 LA9242M; LC78601RE; LA6541 x 3 €7.70 €23.10
You are right. Item description created confusion.
I have sent a new invoice to you and the old one was cancelled.
Tibi
Vicol Audio
Old 31st August 2012, 11:21 AM   #6240
endia is offline endia  Turkey
Hi Tibi,
payment sent for 1 shiga ready mounted and tested,
thanks..
Copyright 1999-2017 diyAudio
