Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 25th August 2012, 11:13 AM   #6221
sigurd is offline sigurd  Belgium
Sorry, yes it is een Pi-pad : output 6K8 to ground, 200 Ohm series, 90 Ohm to ground
Old 26th August 2012, 03:39 AM   #6222
clearaudio is offline clearaudio  Singapore
ez51 for sale
Shigaclone JVC EZ51 bare last 5 brand new | eBay
Old 26th August 2012, 03:24 PM   #6223
truepaul is offline truepaul  United States
Default Now gone ...
These are now taken, as best I can tell. eBay page says 5 are available, but I tried six times and paypal says merchant has stop order in, so this stops the transaction from completing.
Old 26th August 2012, 04:13 PM   #6224
Sean Henderson is offline Sean Henderson  United States
Default Sanyo SF-P101N
Folks,
The transport/laser is a Sanyo SF-P101N, which is available on Ebay from a number of suppliers complete, or available as just the laser pickup assembly. Prices range $12 to $30 USD.
I bought 3 of them for backup parts awhile back, but a word of caution.
Check for binding of the laser pickup assembly on the guide rod and stamped frame by turning the laser pickup assembly drive motor by hand...the laser pickup assembly should move very smoothly with no binding. One of the units I received was binding on the guide rod due to misalignment of the 2 cast in plastic laser assembly through holes that slide on the guide rod. Some careful lapping of the through holes to increase the clearance fixed the problem.
Sanyo SF-P101N | eBay
Sean Henderson
Old 26th August 2012, 07:42 PM   #6225
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Originally Posted by spartan View Post
Tibi,
A question about the 5v circuit.
If I use a separate regulator for the 5v circuit and power it with batteries, leaving the 8v circuit (reg) to be powered by a mains transformer, couldn't that introduce some grounding issues? Do you think it would be better to leave both circuits powered by the same battery supply?
LA6541, beside BTL drivers have a 5V regulator. This regulator will perform a power low and reset of LA9242 and LC78601 at very new CD reading. To separate 8V section from 5V you need to use regulators who can be enabled/disabled via a dedicate pin.
We have tried this with unsatisfactory results.
Also, using batteries, due their intrinsic chemical noise, which is in high frequency domain, IMHO are not recommended.
What I recommend is a supercap, who can be charged between each CD load.
Tibi
Vicol Audio
Old 26th August 2012, 07:45 PM   #6226
tvicol's Avatar
Originally Posted by sigurd View Post
Because the output impedance have a hudge influence on the soundstage 'picture' and 'linearity' , specific of character of sound on solo instruments...!
As far I know 75 ohm is the standard. As already mentioned by uncle_leon, LC78601 do not mention anything about chip output impedance.
Tibi
Vicol Audio
Old 27th August 2012, 12:46 AM   #6227
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Originally Posted by clearaudio View Post
Originally Posted by Sean Henderson View Post
… The transport/laser is a Sanyo SF-P101N, which is available on Ebay from a number of suppliers complete, or available as just the laser pickup assembly.
Is any of those identical to the one offered here, or can serve as a direct substitute?
Old 27th August 2012, 02:55 PM   #6228
guisar is offline guisar  United States
Default No-go with Naim puck.
Originally Posted by tvicol View Post
Naim puck will not work due inner hole is too small. Already tested by me.
Tibi
Rats, I got one too. Have you tried to drill it out? How much interference is there?
Thanks.
Old 27th August 2012, 03:50 PM   #6229
harperrc is offline harperrc  United States
Default simple puck idea
the attached file is a crude drawing of the puck i plan on making. it should be easy to do with simple hand tools (granted you need a reverse tap/die).
Old 27th August 2012, 04:35 PM   #6230
Default SF-P101N CD Mechanism
Joshua,
The SF-P101N CD Mechanism is the same unit you will be getting in the group buy. See past below post from Tibi below...
tvicol's Avatar
Send a message via Yahoo to tvicol Send a message via Skype™ to tvicol
Originally Posted by tonyptony View Post
Tibi, is this the same mechanism which you are ordering?
SF-P101N CD Mechanism SFP101 16 Pins Sanyo Philips Alba | eBay
Oh, and while I know this will be of no real use to virtually anyone else, would anyone know just what it would take to fit a ST glass output to this design? I have two DACs (EAD and Wadia) and both have the ST glass input. Right now I consider that superior to others using my current transport. In my dream for this DIY project I'd love to be able to have a quality ST output available.
Yes, it is the same mechanic.
ST glass output it is an option I´ll consider.
Maybe it will be another separate board with reclocking and AES/EBU, S/PDIF, Toslink and AT&T ST glass.
Do you have any recommendation here for a good ST glass output?
Tibi
Sean Henderson
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
