| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#6211 |
This is how the remote may look.
A single side PCB with all components on the copper side. Regards, Tibi |
#6212 | |
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." |
#6213 |
Short update to project status.
Today we have received the trafos. We expect to have LCD displays delivered on 28. August We´ll receive Shiga PCB boards on 31. August. Remote IR boards are also in production and I expect to have them around 31. August as well. As soon we get PCB boards we´ll start shipping for DIY and Full Shiga Kits. Ready mounted and tested will take off in the first week of September. Thank you for your patience and understanding. Regards, Tibi Last edited by tvicol; 23rd August 2012 at 01:33 PM. |
#6214 |
Thanks Tibi for the update, we appreciate all your hard work.
#6215 |
Tibi,
A question about the 5v circuit. If I use a separate regulator for the 5v circuit and power it with batteries, leaving the 8v circuit (reg) to be powered by a mains transformer, couldn't that introduce some grounding issues? Do you think it would be better to leave both circuits powered by the same battery supply? |
#6216 |
Hi all,
Please, I want to know if the output impedance on the DIGITAL out is about 235 Ohm? That's for calculate an ideal T-pad resistor circuit : attenuator about -10 dB and 75 Ohm output. Thanks. |
#6217 |
Because the output impedance have a hudge influence on the soundstage 'picture' and 'linearity' , specific of character of sound on solo instruments...!
#6218 |
I have really very good results with (after surching with all kind of possibility's ): 6K8 parrallel on direct ouput , 200 Ohm in series to output and 90 Ohm parallel to output : to now that's the best result I have , really nice !
But maybe that would be better ? Some experiences ? |
#6219 |
6k8 to ground, 200 Ohm in series, 90 Ohm to ground : T section
#6220 |
These are some interesting comments you make sigurd, but I am a bit confused as to what actual resistor layout you are using - could you draw a schematic for us, or take a picture? You are saying you have two resistors to the ground + one series, but this sounds like a Pi-pad, not a T-pad?... I'm not nitpicking, just trying to making sure I understand you correctly.
The datasheet for LC78601 doesn't state this, but the digital output impedance is most likely 75Ohm, as per S/PDIF standard. Did you try the 75Ohm Pi-pad I suggested earlier? I built one with my hand-made resistors (which were accurate to +/-0.1R), and I found it to sound far superior to the original L-pad (the detail and resolution took a leap, in particular). I have not tried any further combinations because I assumed 75Ohm should be optimal... But of course, I will be the first to admit that in the audio world theory and practise are often two different stories.
