Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 6th August 2012, 12:11 PM   #6161
tonyptony is offline tonyptony  United States
Has anyone copied/programmed these remote codes into a Pronto type CCF file? If so, could you post the CCF here?
Old 6th August 2012, 12:39 PM   #6162
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
More info about Silan chip, you may find on Product information
Datasheet http://doc.chipfind.ru/pdf/silan/sc7461103.pdf
We are also working on a remote and a CD magnetic puck for this project.
I expect to have both available at the end of August - beginning of September.
Those who ordered now may have the option to get these in one single delivery.
Tibi
Vicol Audio
Old 6th August 2012, 04:25 PM   #6163
Tibi
Thanks Tibi. Any idea what your pricing will be for each?
Old 6th August 2012, 05:25 PM   #6164
tvicol's Avatar
At this time I don't have any calculation, but I can give some ideas about what we are designing.
Remote - is just a small PCB with a 3V Lithium battery, push buttons, IC and IR LED on the same side. This will keep cost low and will allow you to dress in any enclosure you like.
CD puck - I'll go for a NAIM stile. Small simple and efficient.
A small round piece of machined Al, who accommodates a small ring magnet.
Tibi
Vicol Audio
Old 6th August 2012, 06:06 PM   #6165
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi Tibi,
First, create or buy a round long rod of Delrin 6cm diameter and drill a hole exactly in the middle.
Create the delrin so thick that he not go skidding on the CD.
Forget the magnet that sounds not good, listen to classical music then you know what I mean.
My 2 cents,
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 6th August 2012, 07:10 PM   #6166
tvicol's Avatar
Originally Posted by BMW850 View Post
Hi Tibi,
My 2 cents,
Rudy
Hi Rudy,
Many thanks for your suggestion. I agree with you, any magnet puck will affect focus and tracking performance when paying fist ~5-6 min.
I wonder where I'll get Delrin in Romania.
Till we finish our first magnetic puck, I'll stay open to any CD puck project, which is reproductible, easy to make, use cheap materials and is magnetless.
Tibi
Vicol Audio
Old 6th August 2012, 07:46 PM   #6167
zjaakco is offline zjaakco
Hi Rudy, Tibi,
Try it with epoxy, you can pour it in any form, can give it many colours and become very hard.
Zjaakco
Old 6th August 2012, 08:53 PM   #6168
BMW850's Avatar
Hi sjaakco,
Delron sawing on thickness, and then make a hole exactly in the middle.
That is easier than getting hands dirty with epoxy
Rudy
Old 6th August 2012, 11:10 PM   #6169
Can anyone in the EU supply Tibi with some sample Delrin material so he can try it out?
Old 6th August 2012, 11:12 PM   #6170
woodturner-fran is offline woodturner-fran  Ireland
I might have a bit, about 30mm but would need to check.
Fwiw, aluminium will look much better unless you're able to cnc machine the delrin to acheive the finish. Another alternative is a non-magentic brass puck that is just heavy enough to stop the CD from spinning on start up.
Fran
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
