Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 5th August 2012, 12:51 PM   #6151
woodturner-fran is offline woodturner-fran  Ireland
Looks like a good solution Sean...
Old 5th August 2012, 01:05 PM   #6152
tonyptony is offline tonyptony  United States
Originally Posted by Sean Henderson View Post
On the standard SF-P101N 16 pin 16p CD Mechanism, with a CD in place, I then applied an interface layer to the bottom of the magnet so it was contacting the top of the CD, but allowing the 14mm ID surface of the magnet to center on the CD Turntable tapered surface. The result is perfect alignment of the CD Puck.
Sean, this sounds like a great idea. I'm trying to picture what you said about an interface layer, but my imagination is not that good. Can you provide a bit more info about this part - or a drawing or pic?
Old 5th August 2012, 01:07 PM   #6153
Sean Henderson is offline Sean Henderson  United States
Default CD Remote
Is the Sanyo RM-SRCBX330 J Remote Control code compatible with the Shigaclone system?
Sean Henderson
Old 5th August 2012, 09:05 PM   #6154
Default CD Clamp
tonyptony,
I measured the gap between the CD and the magnet resting on the CD Turntable molded taper and then hunted around for a soft material in my stash of stuff that was close to the thickness needed.
There will be some minor variation in the ID of the magnets I needed...I ordered three(3)...though we are talking about .0005 variation, which is nothing to worry about. The bigger variation is the thickness of CD's, but that is +/- .003" or less in the in the sampling I did.
So what I am saying is that with the variables involved here, you will need to experiment with the thickness of the interface material if you use the magnets noted. I happen to have some painters masking tape on hand that was perfect in thickness with one layer and allows the magnet, with the tape in place, to contact all the CD's I tried and provide a slip free grip between the magnet CD Clamp, the CD's I tried, and the Sanyo CD Turntable. Even with the thinnest CD on hand, there was only .002" run-out of the magnet and at the rpm speeds of the CD drive motor, the very slight imbalance is a none issue as the mass variation is at the center of rotation. There is more vibration due to dynamic imbalance in CD's caused be the variation in the centering holes.
There are other type tapes that would work. The beauty is the stuff is cheap and if it needs replacement or more thickness, it is easy to replace, add more, or change thickness as needed.
Sean Henderson
Old 5th August 2012, 09:21 PM   #6155
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Tibi,
Please review my post #6035 and your reply, post #6038 with regard to my order. You have e-mail. Could you send another invoice?
Old 5th August 2012, 09:27 PM   #6156
Thanks Sean.
Old 5th August 2012, 09:38 PM   #6157
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Originally Posted by Ed LaFontaine View Post
Tibi,
Sorry for confusion. Invoice was canceled and a new one sent.
Tibi
Vicol Audio
Old 5th August 2012, 10:54 PM   #6158
Default CD Remote
Tibi,
Is the JVC RM-SRCBX330 J Remote Control code compatible with the Shigaclone system?
Sean Henderson
Old 6th August 2012, 02:14 AM   #6159
chungtat is offline chungtat  Hong Kong
CD Remote
Yes, it is compatible. I tested it with both JVC boombox and Sanyo boombox.
Old 6th August 2012, 07:36 AM   #6160
tvicol's Avatar
Tibi,
Im not able to get schematic for JVC RM-SRCBX330, so I can not advice you.
Original JVC RC-EZ31 use SC7461-103 IC made by SILAN. If your remote have this chip inside, than will work.
Tibi
Vicol Audio
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
