Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 12th July 2012, 02:05 PM   #6011
tonyptony is offline tonyptony  United States
Tibi, how many of Peter Daniel's improvements have been incorporated into this design? I know you didn't replace all the rail caps with BG's , but what about the crystal, removing some of the SMD bypasses, using Caddocks for the output resistors etc? There's so much info in the history of this thread that it's a little difficult to sort out what Peter and others had done, and how much of it is in this completed design.
Old 12th July 2012, 05:44 PM   #6012
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
As many other good things, BG's are history these days. Sanyo OsCon will follow soon as well.
You will find that many Peter Daniel's improvements have been included in our design and few more.
PCB was designed to allow two crystal types ane one metal can (Tentlabs).
For output, you may use any THT resistor including Caddocks.
Also there is the option to insert ferite beads for each IC power stage or to use external power supply's leaving room for further experiments for those who like to do this.
Shiga's sound can be influenced mostly by capacitors, so PCB will accept several capacitor types.
And who knows, together with this great community, may we will discover more tweakings, but now is time to move forward.
Tibi
Vicol Audio
Old 12th July 2012, 08:31 PM   #6013
Jean-Charles is offline Jean-Charles  Canada
Hi Tibi,
I would like to change my order also to
1 assembled and tested Shigaclone.
Thank you
Old 12th July 2012, 11:11 PM   #6014
carpin is offline carpin  Netherlands
carpin's Avatar
Added 1 DIY Shiga KIT
Thanks Tibi
Old 12th July 2012, 11:22 PM   #6015
Tibi
I wonder if, once the product begins to be delivered, we should start a separate thread? Something along the lines of "Turning the new Shigaclone into a Giant Killer". There are certainly a ton of great ideas here, but I think it might be worth a new thread just for those interested in tweaking it to be better than the giants past and present.
Old 12th July 2012, 11:23 PM   #6016
woodturner-fran is offline woodturner-fran  Ireland
I'm just waiting on a response from a friend (we both built shigas) - its likely I'll be changing to at least 1 full built shiga.
Be back ASAP with a proper response
Fran
Old 13th July 2012, 05:00 AM   #6017
tvicol's Avatar
Originally Posted by Jean-Charles View Post
Hi Tibi,
Thank you
Done with thanks !
Tibi
Vicol Audio
Old 13th July 2012, 05:02 AM   #6018
tvicol's Avatar
I completely agree with you.
Tibi
Vicol Audio
Old 13th July 2012, 06:06 PM   #6019
Tibi, please change my order from 2 set of boards etc to 2 fully assembled and tested kits please!!!
Fran
Old 13th July 2012, 06:22 PM   #6020
tvicol's Avatar
Fran
Done with thanks !
Tibi
Vicol Audio
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
