Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 1st July 2012, 06:04 PM   #5921
c12mech is offline c12mech  United States
c12mech's Avatar
Uncle Leon, this is good news indeed. Once I get the project that I am building for someone else I plan to actually finish my original transport. Considering it has been mounted on a board on my desk for over a year, it can wait a little longer.
Just so I am clear on this, it goes on the digital out and ground. The series resistor is on the dout and the parallel resistors on the ground.
Old 4th July 2012, 12:25 PM   #5922
Audiohifi is offline Audiohifi  Singapore
Hi Tibi
LCD display problem resolved. Thanks
What about the remote controller?
So far have not been the sample.
Another thing is that I will go for your fully completed and tested
set rather than struggle with the smd. Hope you will post the prices
soon so that we can place order
Old 4th July 2012, 02:22 PM   #5923
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Originally Posted by Audiohifi View Post
Hi Tibi
Hi audiohifi
I'm looking to source original chip and build a pcb remote, but remote remain optional as long any universal one should do the job.
As I already stated, there will a limited set of ready mounted and tested kits starting with 1st august.
Tibi
Vicol Audio
Old 5th July 2012, 08:48 PM   #5924
Dr.H is offline Dr.H
Hi guys, a short post on reclocking the spdif output. Reclocking is believed to reduce the jitter on the signal. The effect on sound? In my setup, more detail, more precise sound without hardness.
Very simple to implement:
1. Obtain data sheets for 74hc74 and 74hc04
2. on the 74hc74, pin 1, pin 4 and pin 14 are all connected to +5V; pin 7 is connected to ground; pin 2 is where the dirty original spdif is fed in; pin 3 is where the "new" clock is connected (see point 3); pin 5 will be the output of the "clean" spdif
3. On the 74hc04, pin7 is connected to ground; pin14 goes to +5; the original clock goes into pin 1; pin 2 is connected to pin 3 and the new clock is taken out of pin 4 of the 74hc04; this output is connected to pin 3 of the 74hc74;
Post results here.
Ryan
Old 6th July 2012, 01:13 PM   #5925
spartan is offline spartan
Does anybody know what is the exact current drawn from the 5V circuit on the shiga clone? I'm thinking of using highpower batteries to power that circuit with the appropriate regulation on them.
Old 8th July 2012, 12:53 PM   #5926
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Default 5V supply Currents
Spartan,
I can't point to it exactly, but there was info about power supply current requirements in this thread and in the Tvicol era. Start looking around Feb, 2012, maybe about post #5230, and look forward for a picture of a Bobken power supply or something like that. That should put you in the area where the supply requirements were discussed.
By the way, you might try checking the Salas power supply thread too. Early in the development of his supply, someone discussed or linked to a study of wall powered supplies .vs. battery. If memory serves, the batteries weren't as good as I was expecting.
Old 9th July 2012, 12:10 AM   #5927
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I just signed up for the GB (3 from each). Just a question. Will the boards be pre-populated? I started reading backwords to find more info but got lost...
Old 9th July 2012, 12:47 AM   #5928
dimkasta's Avatar
Nevermind just found the asnswer
i will pay as soon as you give usnthe green light
Old 9th July 2012, 06:42 AM   #5929
Guys, it turns out that 74HCU04 is better than the 04 in the spdif reclocking circuit. More resolution.
Old 9th July 2012, 11:26 AM   #5930
Default PCB list
Originally Posted by tvicol View Post
Hi audiohifi
Tibi
Hi there, can you add me to your list for the PCB?
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
