Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 2nd May 2012, 06:15 AM   #5821
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
In understand that some of you may lost their patience, but display is a must for any CD player/transport.
The display board will have two options:
1. direct drive to LCD
2. drive to LED matrix trough atmel
Tibi
Vicol Audio
Old 2nd May 2012, 07:08 PM   #5822
zjaakco is offline zjaakco
Hi tvicol
Please take your time to finish this wonderful project
It is the right way to get a good working project
Yes, a lcd is necessary.
regards
zjaakco
Old 2nd May 2012, 10:11 PM   #5823
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Unhappy Sorry for causing trouble
Tibi,
I didn't mean to stir the hornets nest with my suggestion. Naturally, a display is better if possible.
As for me, I'm not growing impatient at all. I really appreciate all the effort that you especially and others have put into this project. It seemed from the outside that things were getting difficult in the area of the display. I didn't have any knowledge that would help you find a solution, so tried thinking out of the box. Sorry for causing trouble.
Overall, we are all with you and will support you in any way we can.
Old 3rd May 2012, 08:51 AM   #5824
tvicol's Avatar
lehmanhill,
No trouble al all, sorry if I made myself wrong understood.
I just wanted to give an update.
The project is going further and all I want is to offer a better transport.
Tibi
Vicol Audio
Old 18th May 2012, 01:14 PM   #5825
Praudio is offline Praudio
Tibi
Don't forget an off switch(on remote if possible,and if not add some$) for display, my Meridian 602 is on 24/7/365 for years and my display is off at 99.99%
Praudio
Old 18th May 2012, 01:23 PM   #5826
tonyptony is offline tonyptony  United States
+1
Old 18th May 2012, 01:23 PM   #5827
DaveM is offline DaveM  United States
DaveM's Avatar
That is something you can put in yourself. Just break the power to the display. No issue. Good thought though....
Old 18th May 2012, 01:31 PM   #5828
tvicol's Avatar
The display is a multiplexed LCD and can not be switched off unless you power off the DSP.
Anyhow, we have ordered an transmissive LCD with back-light and switching off the back-light will give you the effect needed. :-)
Tibi
Vicol Audio
Old 19th May 2012, 12:49 PM   #5829
BTW is offline BTW
Hi Fran,
Just to feedback... Thank you very much sharing the Precision Attenuators approach.. I tried it ... yes much better than using resistors alone.. as you can easily dial in and optimise the sound... I ended up with a total of 30db attenuation..
Originally Posted by woodturner-fran View Post
Right now I'm using a 20dB at one end of the cable and a 15dB at the other end. I did try them directly in series but I couldn't tell any difference. I'm using a buffalo dac (one of the earlier ones) and it stays locked no problem at that level. I think if I were ordering them up I would order a few - maybe get a 2 x 15db, 10 and a 6 as well. That would give you many combinations. That 25+15 was the highest amount I could go without causing dropout on the spdif line, so if your dac needs a slightly higher signal to lock on, then it might not work with that much attenuation.
Fran
Old 22nd May 2012, 12:48 PM   #5830
tvicol's Avatar
Default Prototype board
Prototype boards are ready. :-)
Tibi
Vicol Audio
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
