Finally, an affordable CD Transport: the Shigaclone story - Page 579 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th April 2012, 02:05 PM   #5781
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Not according to the manual:
"Horizontal: Laser light emitted from the objective lens should be in the + direction
of Z-axis (- direction of gravity)."
Old 11th April 2012, 02:48 PM   #5782
jmltinc is offline jmltinc  United States
Ah, the manual...
Have you a link to the manual or a datasheet? Google has failed me on this.
Thanks,
-John
Old 11th April 2012, 03:01 PM   #5783
TheGimp's Avatar
No, but the manual names are DA11B3VZ.pdf and DA11VZ.pdf.
They should be easy to find. Ignore the preliminary ones.
The ones I have are from "Common Ways International"
Old 11th April 2012, 03:11 PM   #5784
Well thanks. I would have searched a very long time.
-John
Old 12th April 2012, 09:41 AM   #5785
morpheous's Avatar
Send a message via Yahoo to morpheous
@tvicol
what do you think instead of to use MSR860 use LQA03TC600 Mouser code 903-LQA03TC600 ?
LQA03TC600 Power Integrations Rectifiers
Francesco.
Old 12th April 2012, 10:49 AM   #5786
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Originally Posted by morpheous View Post
@tvicol
Francesco.
Francesco,
You can use any rectifier you like as long this will fit the PCB.
If you look in schematic we have recommended silicon-carbide CREE CSD-01060A. IMHO silicon-carbide CREE are the best rectifiers currently available in market.
Tibi
Vicol Audio
Old 14th April 2012, 03:18 PM   #5787
Hi, I have a problem with my shigaclone.
If I try to play a cd, the player does not respond.
This is on the remote control and the control with the display.
If I close the switch, turns the cd neat and sees the numbers.
Only when I push the play button nothing happens. What can be the cause? Laser or print?
Matthijs
Old 14th April 2012, 03:28 PM   #5788
So the shiga can spin up and read the TOC correctly?
Very likely something to do with the play switch and the connection from that to the main board. Try removing and re-inserting the ribbon cable? Do the skip buttons work OK on either the remote or the buttons?
Fran
Old 14th April 2012, 04:16 PM   #5789
Yes, it spin up and read toc correctly.
The skipp buttons on the remote and the other buttons donīt work.
I already re-installed the ribbon cable.
Old 14th April 2012, 05:09 PM   #5790
OK, If it reads the TOC ok then I don't think there is anything wrong with the crystal or mechanism. It seems more likely that there is some kind of break between the display board and the mechanism - so when the button is pressed or the IR receives a signal, it isn't transmitted to the main board. IIRC, all those buttons are normally open types - can you short one at the display board, and then do the same thing at the correct pins where the ribbon cable connects in? You could also test for continuity at either end of the ribbon cable too.... It wouldn't be the first time the ribbon cable was damaged....
If its not the cable/connection somehow I'm stumped.
Fran
Copyright Đ1999-2017 diyAudio
