Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 18th March 2012, 10:43 AM   #5651
woodturner-fran is offline woodturner-fran  Ireland
Originally Posted by BTW View Post
Hi Fran,
Think I'll give your RF attenuators recommendation a try.. I just like to know currently which combination works best for you... 10dB + 15dB ? Another question, instead of putting the 2 RF attenuators in series, have you tried putting the 2 attenuators at either ends of the DAC and Shigaclone.. and any difference ? .. my rack's quite close to the back wall.. might be a tight squeeze if I put the 2 attenuators back to back.
Right now I'm using a 20dB at one end of the cable and a 15dB at the other end. I did try them directly in series but I couldn't tell any difference. I'm using a buffalo dac (one of the earlier ones) and it stays locked no problem at that level. I think if I were ordering them up I would order a few - maybe get a 2 x 15db, 10 and a 6 as well. That would give you many combinations. That 25+15 was the highest amount I could go without causing dropout on the spdif line, so if your dac needs a slightly higher signal to lock on, then it might not work with that much attenuation.
Fran
Old 18th March 2012, 12:13 PM   #5652
BTW is offline BTW
Hi Fran,
Thanks a lot for the information... I'm using the Buffalo 2 with Diyhif Supply UTS... so should be quite similar to your set-up. I'll arrange to buy some of these attenuator as per your recommendations to try out...
Fran
Old 18th March 2012, 07:40 PM   #5653
uncle_leon is offline uncle_leon  Poland
uncle_leon's Avatar
Fran
I wonder just how much better the attenuators are from the resistors you've tried. I have recently made my own resistors, which literally transformed my Shiga sound when installed at the output. Would be interested in a little comparison, Fran?
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 18th March 2012, 10:54 PM   #5654
jazz35 is offline jazz35  Romania
jazz35's Avatar
This is the design proposal for our shiga pcb.
As you can see in the schematic provided, this board will accomodate different types of components. For an easy identification the alternative/additional components (ex: LTs regs & additional components, TentLabs oscillator, etc) are marked with an white rectangle.
Bottom side
Top side
Any sugestion ?!
jazz35
Old 19th March 2012, 12:55 AM   #5655
rikkert1978 is offline rikkert1978  Netherlands
Fantastic work on the design!
Old 19th March 2012, 01:37 AM   #5656
Jazz35: not qualified to offer any opinion, but it looks great!
Uncle leon: sounds like a good idea! I was using rikens in there before, the blue ones with the gold leads. How do you suggest to proceed?
Fran
Old 19th March 2012, 03:24 AM   #5657
skippyboy is offline skippyboy  Australia
skippyboy's Avatar
If you order a transport from youpay do not forget to order the cable, i forgot, duh
Old 19th March 2012, 08:37 AM   #5658
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Thank you !
We are going to move further with power supply board and display.
For display well use a three digit one. Two digits for cd track and one for other signs. Ex: for play - P; for pause || etc.
If you have any suggestions/observations/critics please express them now.
Tibi
Vicol Audio
Old 19th March 2012, 09:17 AM   #5659
samoloko is offline samoloko  Bulgaria
what would be freq of Xo2
shiga oscillator Is 16.934MHz but CD audio works with 11.289 MHz
Old 19th March 2012, 09:32 AM   #5660
tvicol's Avatar
XO2 is 16934400Hz
In general any CD transport will use an oscillator with multiple of 44100Hz (CD sampling rate).
In our case 384 x 44100 = 16.934400MHz
Tibi
Vicol Audio
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
