Finally, an affordable CD Transport: the Shigaclone story - Page 562 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th March 2012, 07:26 PM   #5611
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
We will see, i would suggest to wait for the draft design of Shiga PCB and i could redesign PCB to fit neatly on it with 3 pin terminal.
BUT and here is a big but we should first ask Peter Daniel if we can do this since he was the one who published the design !!!
Old 15th March 2012, 08:00 PM   #5612
Ooops - good point - didn't think of that though the sketch of the design was
published for us to p2p copy wasn't it ?
Old 15th March 2012, 09:11 PM   #5613
hotiron is offline hotiron  Scotland
hotiron's Avatar
Just sim'd this reg. Results are pretty impressive. I'm off to build one.
If you give up easily Dont start!!
Old 15th March 2012, 09:24 PM   #5614
You mean you had all those bits lying around in your box ?
Blimey !
Old 15th March 2012, 09:25 PM   #5615
uncle_leon's Avatar
The design is actually Bobken's, and he is happy for everyone to use it.
Please keep in mind that his reg is so good partly because all its components have been carefully selected "by ear". In other words, I suggest that you stick to Peter's recommended components unless you have a good reason to deviate from his choices (like the expense of buying a 10uF BG N).
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 15th March 2012, 10:45 PM   #5616
skippyboy's Avatar
Current "youpay" 1- pair 2200 =GBP 100
1- pair 10 =GBP 40
I think not for me, will look for a different solution.
Old 15th March 2012, 11:16 PM   #5617
Yes, it will be a bit pricey. What are the total voltages needed? I see at least +8 VDC and +5 VDC. Anything else?
Old 15th March 2012, 11:22 PM   #5618
uncle_leon's Avatar
Black Gate FK are not a part of the regulator itself, they are just in the Peter's recommended PSU configuration.
If you can't afford Black Gates, consider using a 2200uf Elna Starget and a 1000uf Sanyo Os-Con instead - they sounded best in my extensive capacitor tests. I would also pick Os-Con for the 10uf position as it sounds slightly more accurate than Starget, but some people prefer the warmer Starget signature. Stargets also benefit more from wood-modding (if you take such things into consideration).
Old 15th March 2012, 11:40 PM   #5619
massimo is offline massimo  Italy
Should the big 3W resistor be 3 or 15 ohm?
According to the sim 15 ohm leads to 0.017A CCS. Am I right?
Old 16th March 2012, 03:36 AM   #5620
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I've started gathering components for my Shigaclones, and have a nice section of copper plate for the base/bases.
the plate measures 10.5" (26.7cm) X 4" (10.16cm) X 1/4" (3.56cm).
Is this large enough for two units or should I just use it for one? It seems quite massive compared to the transport mechanism.
Copyright 1999-2017 diyAudio
