| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#5531 | |
I would offer that if this base design is considered good enough to be used as a foundation for its own improvements, any such improvements should be considered within the context of being able to fit into said design. If it can be done in a way that allows for these features to be incorporated as desired then I think it will keep the DIY-friendly aspect intact. But such improvemnts may wish to be considered now to see if it will require small perturbations to the current design, to allow for later implementation. As for RCA out, yes it is the most common interface. Perhaps if there were a way to fit the PCB with the pin and pitch layout for either RCA or BNC it would then leave the builder with the opportunity to fit the interface to support their need? It would then allow for a proper 75 Ohm output to be inherent on the board. For sizing purposes I'd recommend something like an Amphenol 031-70221. |
#5532 |
I see what you are saying, tonyptony, and you do have a point.
Another thought has just occurred to me - why any connectors should be mounted on the control PCB in the first place? Most people, I suspect, will prefer to have the connectors mounted to their cases - hence my proposition is, let's leave the digital output "bare", similar to what we had with the original Shiga. The choice (and wiring) of connectors will be then up to the constructor.
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." |
#5533 |
That sounds reasonable. As long as it can be done in a way that would not compromise the ability to get a true 75 Ohm signal path to the back panel. I expect AES/EBU Type I could be done the same way. Optical of either sort would have to be board mounted, I think.
#5534 |
If this is a laser/Diode output, and not the receiver photo-diode/phototransistor, shouldn't it be relatively insensitive such that a section of something like RG-174 wold be sufficient as long as one was talking about a couple of inches (<6" / <15cm)?
#5535 |
hi,
I put a jvc rcez 31 on ebay,I didn't want to sell it ,but need the cash,I hope someone will enjoy it and forgive me mods for posting it here but I thought everyone would see it here,Thanks http://www.ebay.com/itm/120872864639...84.m1555.l2649 |
#5536 |
I prefer BNC as well, the others might be optional. I also support the idea of having the PCB on its own.
Brgds
These are my principles, and if you don't like them... well, I have others. |
#5537 |
The board we are currently designing will have digital output only trough a small PCB connector.
Is up to end user which connector will use. The reclocking board who will support all possible connectors and interfaces: BNC, XLR, RCA, TOSLINK, AT&T ST glass is part of this project, but we´ll design this later. A lot of investigation need to be done on the reclocking circuit, AES/EBU trafo, Toslink and especially on AT&T ST glass. Some extensive tests and measurements need to be done as well. Therefore this board will come later to complete this project. Thanks & Regards, Tibi |
#5538 |
I managed to find a BNIB RC-EZ51H for
#5539 | |
Thank you Tibi. That's good enough for me. Can you tell us what the PCB layout and spacing is for the board mounted connector? |
