Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th March 2012, 03:09 PM   #5511
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I agree that isolating the board from the motors is important. One question in my mind is how far is far enough?
An additional idea is to add a Mu-Metal shield between the motors and the board. I don't see that any spacing option would preclude this.
How good is the internal DAC option?
I was expecting to use an external DAC (WM8741) but it might be nice to compare the two for myself since I have no experience with such.
Old 6th March 2012, 04:06 PM   #5512
uncle_leon's Avatar
Originally Posted by massimo View Post
Keeping the small pcb and sw on the mech and connecting it to the new main pcb, not only offer Jazz more freedom in designing the pcb, but also isolates the motors from the electronics. Somebody in the past reported this as beneficial sound wise.
It's an option I would consider......
I'm definitely with massimo on that.
I don't quite see the point of discussing the length of the ribbon cable at this stage though (but maybe I'm missing something?...). The way I'm imagining it, we will have a "control PCB", which we will be able to connect to any compatible CD mech in any way we please - with a short ribbon, with a long ribbon, hard-wired or whatever. As BMW850 rightly pointed out, closer is not necessarily better, and some degree of separation will almost surely be beneficial. Everyone can decide for themselves how far to go with separating the two components when they actually build the player as there will inevitably be other constraints to consider.
@TheGimp - the internal DAC is ok-ish, but nothing to write home about... It has a fairly bright sound, mediocre bass control and a typical "digital" timbre.
Studio Zèy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 7th March 2012, 12:38 AM   #5513
Originally Posted by tvicol View Post
I'm going to order 50 CD-mechanic SFP101N-16P-DA11V.
Tibi, is this the same mechanism which you are ordering?
SF-P101N CD Mechanism SFP101 16 Pins Sanyo Philips Alba | eBay
Oh, and while I know this will be of no real use to virtually anyone else, would anyone know just what it would take to fit a ST glass output to this design? I have two DACs (EAD and Wadia) and both have the ST glass input. Right now I consider that superior to others using my current transport. In my dream for this DIY project I'd love to be able to have a quality ST output available.
Old 7th March 2012, 06:26 AM   #5514
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Yahoo to tvicol Send a message via Skype™ to tvicol
Thank you all for your opinions!
The benefits for having a separate board are obvious.
- less mechanical vibrations, less noise induced by ceramic components
- more space to accommodate 1206 components
- better layout and grounding as the motors are no longer on pcb
- flexibility in terms of board placement - dampening, shielding etc
Jazz and me will change the design for a separate board.
The board will be mounted under cd mechanic, something like in picture posted by Rudy http://www.diyaudio.com/forums/attac...ry-oil-rig.jpg
Tibi
Old 7th March 2012, 06:54 AM   #5515
tvicol's Avatar
Yes, it is the same mechanic.
ST glass output it is an option I´ll consider.
Maybe it will be another separate board with reclocking and AES/EBU, S/PDIF, Toslink and AT&T ST glass.
Do you have any recommendation here for a good ST glass output?
Tibi
Old 7th March 2012, 07:14 AM   #5516
tvicol's Avatar
Can be an option
Laser -> http://www.optekinc.com/datasheets/OPV314AT.pdf
LED TX -> http://www.optekinc.com/datasheets/OPF694.PDF
LED RX -> http://www.optekinc.com/datasheets/OPF560.PDF
And here an application note from HP
http://server.elektro.dtu.dk/ftp/dat..._apps/ab78.pdf
And an old thread Fibre optic - AT&T style (HP, Optek,...)
Tibi
Old 7th March 2012, 08:28 AM   #5517
massimo is offline massimo  Italy
Very good idea, Tibi!
I understand Wadia user, but I support AES/UBS over the rest.
Old 7th March 2012, 08:35 AM   #5518
syklab is offline syklab  Hong Kong
Totally agree.
Old 7th March 2012, 09:18 AM   #5519
Ivo-Cici's Avatar
Send a message via MSN to Ivo-Cici
Many, option????
Wonderful, I agre!
Ivo-Cici
Old 7th March 2012, 02:56 PM   #5520
Tibi
No Tibi. I wish I did. My experience is only with the older ODL 50 types and one from HP.
I understand massimo's preference, but I do hope for a ST solution. Many older higher end DACs used ST glass. It's a much better interface than Toslink (for those who can use it).
Copyright ©1999-2013 diyAudio
