Finally, an affordable CD Transport: the Shigaclone story - Page 546 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th February 2012, 06:48 PM   #5451
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Originally Posted by TheGimp View Post
Hmmm. Actually a couple of resistors and a transistor would work just as well.
The only advantage of inverting the signal is to eliminate the NC switch and use all NO switches.
This simplifies the BOM and makes purchasing parts easier at the expense of the additional resistors and transistor.
With regards to the ADP151, one could pre-regulate the 8V supply down to 5V with a 7805 to generate a supply that is supportive. Again, it adds components. However if 8V tolerant low noise regulators are difficult to source it may be worth investigating.
Maybe we'll make room for something like this on PCB, but I'll try to keep balance between options and price on the side of price. Also a very complicate PCB with lot of options will confuse DIY-ers.
Tibi
Vicol Audio
Old 27th February 2012, 07:11 PM   #5452
tvicol's Avatar
Originally Posted by Nomdi View Post
A L7941 is a serious outsider to replace a 7805...
@tibi : could you consider to add 2 capacitors
to replace the ceramic resonator with a regular quartz ?
Good a low cost upgrade to my mind...
Nomdi,
Please a datasheet for L7941 ?
Actually the resonator will no more be used in this project.
This is already reflected in schematic I'll post in few moments.
Thanks & Regards,
Tibi
Vicol Audio
Old 27th February 2012, 07:41 PM   #5453
tvicol's Avatar
Schematic with latest changes.
- ADP151 low noise regulator for Vref=2.5V
- separate power supply for each pin on LA6541. I don't have LA6541 detailed internal connections, hope this will bring us separate BTL for focus&track from motors.
- N.C. switch is on the display board
- instead ceramic resonator a citizen cristal is in place
- all other small error drawings have been corrected
From now will start to work on PCB, but remain open to any other observation/suggestions.
Thank you !
Tibi
Vicol Audio
Old 28th February 2012, 10:14 PM   #5454
skippyboy's Avatar
Found this, is it of any use for the Shigaclone project or am i off track.
CD rom drive control
CD ROM drive controller board products AR | eBay
Old 29th February 2012, 03:39 AM   #5455
TheGimp is online now TheGimp  United States
TheGimp's Avatar
I think that is designed to interface to an IDE CD rom drive. It uses a microprocessor to talk through the IDE interface to operate the drive.
Third pix from the bottom shows the back side with what looks like an IDE connector.
Last pix looks like a housing with the controller, a ps and the CD rom drive in the bottom.
Old 29th February 2012, 06:57 PM   #5456
tvicol's Avatar
I had a look on the schematic from this post Finally, an affordable CD Transport: the Shigaclone story
I don't get why Vref from regulator output need to go back to Vref from LA9242.
Is there any feed-back in place ?
Tibi
Vicol Audio
Old 29th February 2012, 07:31 PM   #5457
Added my name to the list. This is a very commendable project - well done to all concerned.
Fran
Old 29th February 2012, 07:35 PM   #5458
Tibi
From my understanding its based on a feedback loop that monitors and regulates the vref signal from the LA9242
Old 29th February 2012, 08:05 PM   #5459
tvicol's Avatar
In LA9242 datasheeton page 16, you will see that Vref is made with a differential stage who mirror a low current resistive reference to a high current reference (see npn/pnp complementary pair).
I don't see any reason to use Vref LA9242 in a feedback loop with a low noise regulator.
In fact this will inject Vref La9242 noise back to C906.
A more elegant solution could be to inject at pin 57 a low noise low current reference.
Can you please disconnect regulator and C906 from LA9242 Vref pin ?
I expect better results.
Tibi
Vicol Audio
Old 29th February 2012, 08:30 PM   #5460
Tibi
I really didnt notice any improvement when I implemented the regulator to C906. I will disconnect it tonight and see if I notice any change in sound.
Copyright 1999-2017 diyAudio
