Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 27th February 2012, 07:55 AM   #5441
tvicol is offline tvicol  Europe
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Originally Posted by syklab View Post
Hi Tibi,
I think Q2 should be 2SB764.
Yes, you are right. IŽll correct this as well.
Tibi
Vicol Audio
Old 27th February 2012, 08:10 AM   #5442
massimo is offline massimo  Italy
Originally Posted by tvicol View Post
massimo,
Can you please give me a link to AD151 datasheet and a source for component ?
IŽm not sure I understand completely what N.O. buttons are you referring too. Do you have a draw ?
Tibi
Regs: I wrote AD151 having in mind the maker, Analog Device, but the correct designation is ADP151, sorry. With these regs you save a cap
ADP151 | Ultra Low Noise, 200 mA CMOS Linear Regulator | Linear Regulators | Power Management | Analog Devices
Normally Open (N.O.) switches are the one used fo Play, Stop, forward skip and back skip. For the "cd door switch" you need a Normally Closed (N.C.) switch and push it (disconnecting IC's pin from GND) to start reading the disc. Thus you cannot use the same buttons.
Old 27th February 2012, 08:23 AM   #5443
tvicol's Avatar
massimo,
Thanks for the info.
ADP151 input voltage range is too low to be used in this application (2,2V to 5,5V). We need a reg with at least 8V input. Also the regulator need to be able to dissipate at least 150mW in normal operation.
However, his very low noise and low footprint make him suitable to Vref syklab is talking about.
IŽll take in consideration to use him in Vref.
OK I got your point. Will search for a N.C. switch.
Tibi
Vicol Audio
Old 27th February 2012, 09:13 AM   #5444
tvicol's Avatar
Default ADP151
massimo,
Even LP5900 is a strong candidate, this is not available in TSOT package, therefore very hard to work with from DIY perspective.
ADP151 is available in TSOT package, but not available on mouser, farnell or tme.
Do you have a source for ADP151AUJZ-2.5-R7 5-Lead - TSOT package ?
Tibi
Vicol Audio
Old 27th February 2012, 02:04 PM   #5445
TheGimp is offline TheGimp  United States
TheGimp's Avatar
massimo,
Tibi
Or, you could use a 74AHC1G06 (single gate open drain inverter) to invert the polarity of the signal and use the same switch for all positions.
Old 27th February 2012, 03:03 PM   #5446
tvicol's Avatar
It is a valid suggestion and I'll keep it as last resort.
I prefer to keep things simple.
Tibi
Vicol Audio
Old 27th February 2012, 05:07 PM   #5447
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
This is nice to see that everyone helps each other to reach a good end result
Tibi continue with the good work
Rudy
It’s not what you know, but who you know “and where they are”
Old 27th February 2012, 05:30 PM   #5448
TheGimp's Avatar
Hmmm. Actually a couple of resistors and a transistor would work just as well.
The only advantage of inverting the signal is to eliminate the NC switch and use all NO switches.
This simplifies the BOM and makes purchasing parts easier at the expense of the additional resistors and transistor.
With regards to the ADP151, one could pre-regulate the 8V supply down to 5V with a 7805 to generate a supply that is supportive. Again, it adds components. However if 8V tolerant low noise regulators are difficult to source it may be worth investigating.
Old 27th February 2012, 06:32 PM   #5449
Nomdi is offline Nomdi  France
A L7941 is a serious outsider to replace a 7805...
@tibi : could you consider to add 2 capacitors
to replace the ceramic resonator with a regular quartz ?
Good a low cost upgrade to my mind...
Old 27th February 2012, 06:43 PM   #5450
tvicol's Avatar
Rudy
Thank you, Rudy !
Tibi
Vicol Audio
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
