| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#5421 | |
LA9242M will benefit from two low noise regulators. One is for laser and RF section and I expect that Vref to benefit as well. What current this new 2.5V regulator need to provide ? Regards, Tibi Last edited by tvicol; 26th February 2012 at 05:27 PM. |
#5422 | |
SANYO LASER LENS SF-P101N DA11B3VF (16P) W/MECHANISM SFP101N | eBay puckless version |
#5423 | |
puck version |
#5424 |
I still don't know where to get the LCD display to use
#5425 |
Me too, so a standard two digit display will be used instead.
DE112RS-20/6.35 DISPLAY ELECTRONIK - Afi?aj: LCD | Transfer Multisort Elektronik Regards, Tibi |
#5426 | |
#5427 |
#5428 | |
#5429 | |
One thing that occurs to me after checking it, is that it still has the bypasses for all the electrolytic caps. One of the basic mods was to remove some of them, because they were detrimental to the sound, so perhaps we could remove them all at this stage? On the other hand, there is naturally no harm in making the room for them on the PCB, and leaving it up to the end user to install them or not (which is probably the best way forward). Also, am I right in thinking that R6 (100R) should be moved to between C2 and C10? Edit: another thought just occured to me: are we going to use 2SA608NF and 2SA1342 for Q1, Q2 and Q3, or are we replacing them with some other suitable transistors? I have just checked and both the original types seem to be available - albeit a bit scarce.
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." Last edited by uncle_leon; 26th February 2012 at 09:35 PM. |
#5430 |
Hi tvicol
If you can make choiches for a final pcb, please consider for separete power supply and room for a decouple cap of 1000uF/16V for the motor-drive ic, This mean 8V to the transistor, and 2x 8V for the other power pins. It save me (us) a lot of work. If possible give every power pin a seperate power supply. This will certain be an improvement. Regards zjaakco |
