| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#531 |
Peter, given Johnm's findings, can you just confirm that of the mods listed by Okapi, If I were to remove the items he has removed, and leave the rest as standard, it will still work ?
http://tim.cheapo.cc/images/CD%20player%20mods.pdf If that is the case, why were they there in the first place ? In relation to the 75/75 resistors on the dig out. I tried this and got a lot of hum. Can I just check I got the wiring right. One resisitor goes from the + side of the dig out to Phono and the other intersects and goes to ground, at one (transport) end only ? http://www.diyaudio.com/forums/attac...amp=1208083104 Finally, can you confirm you got payment from PayPal. |
#532 | |
Sorry not to answer earlier, Internet has been down. I used schottky fast diodes, 1N5821. Thanks guys for the complements, hope it gave some inspiration.. JohnM, try adding a 150R to the series output, it may just be the simple solution.. |
#533 | |
post #317 |
#534 | |
You package was shipped last Friday, if you find that some parts are not needed, you can send them back for a refund (providing jackets are perfect condition and pins at least 5mm long).
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#535 |
Thanks Peter. Any comments on :-
"If I were to remove the items he has removed, and leave the rest as standard, it will still work ?" And "In relation to the 75/75 resistors on the dig out. I tried this and got a lot of hum. Can I just check I got the wiring right. One resisitor goes from the + side of the dig out to Phono and the other intersects and goes to ground, at one (transport) end only ? OR BOTH ?" |
#536 | |
There is no + side of digital signal marked on a board. There is +5V which you dont' use, DOUT which is digital signal and GND. Series resistor connects to DOUT, shunt resistor connects between series resistor output and GND, as on schematic posted by Stefano.
#537 | |
#538 |
Just for fun , this is the schematic of the 8 volt internal regulator of the JVC RC EZ31 .
#539 |
After going back a few posts to where the jumper is required on the stock PS board to replace the switch on the AC cord input, the system (guts of EZ32) is alive.
The EZ32 has a 7808 regulator on it, so will work for now while I work on Kevin's mods to get rid of the audio board. Waiting for some of those $3 25VCT transformers from Parts Express to arrive while laying out a new board. Took the small 3 pin header off the corner of the audio board and put it in the holes where the DOUT is located on this unit, so I can play with the SPDIF loading without having to touch the board, but it sounds nice for now with 390/100 ohms, feeding one of Peter's NOS DAC's. Now the real fun begins. Thanks to all for help in this thread. Craig |
#540 |
Happy to report that removing the ferrite on the ac power leads to the stock transformer effected a pretty big improvement. The mechanical sound quality I complained about in my last post is mostly gone.
I tried several other EI transformers and noted no particular sonic advantage while listening so I stuck the stock transformer back in my transport. It fits and some of the bigger ones really do not. Finally I added a couple of small 33uF/63V Nichicon VZ series caps at the output of the 8V supply. I noted some improvement in the smoothness of the highs, and a slight improvement in overall imaging. I did not use BG caps in my supplies so I cannot indicate whether or not this would result in an improvement or not. I am now also able to use the remote control. For whatever reason this thing certainly is revealing, far better in some respects perhaps than any cd player I have owned to this point. I am sometimes amazed at what it does for multi-track vocals, it resolves rather well.
www.kta-hifi.net |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| jazz35 |
| Page generated in 0.17751 seconds (73.39% PHP - 26.61% MySQL) with 11 queries |
