Finally, an affordable CD Transport: the Shigaclone story - Page 513 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th November 2011, 03:42 PM   #5121
uncle_leon's Avatar
For both Vishays and Caddock, I suggest Michael Percy (percyaudio.com) - he has the full range of Vishay values available, and stocks all flavours of Caddocks as well. Ordering is a bit awkward (you have to send him an email listing the parts you want, and wait for reply which can be a few days), but his prices are very good on most items and he accepts PayPal.
If you only want two resistors, this might be a bit expensive though because of postage etc... Check with Michael first - if it's too expensive, let me know and I will send you mine (if you don't mind second-hand). I have recently moved entirely to hand-made resistors, which are in every way superior - and have no intention of going back to commercial stuff, so I don't need them any more.
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 20th November 2011, 04:24 PM   #5122
Problem is I only need 1set. I actually don't mind secondhand. But thank you for link this shop is amazing..I think I wrote to you in the shorter version of the shigaclone. If you tried the Duelund Alexander cap in c906. I have one o,1uf but haven't used it yet. I have read all your test but ended with silmic ii in c916 did not try Elna stargete because I could not locate a reseller, but silmic was in my setup prefered over oscon..I guess I found it to light/hard in sound but with good resolution. I think this changing caps is quite a part of the shigaclone fun
Old 20th November 2011, 10:54 PM   #5123
uncle_leon's Avatar
It is fun indeed - or at least it used to be, until I heard a setup based entirely on wood-modded Black Gates Since then, I kind of gave up searching, because I don't believe I will find anything better - not within the next ten years anyway... I still do a bit of cap listening every now and then, "pro publico bono" so I can help those who cannot afford Black Gates (Black Gates can still be bought, only their prices are extra-orbital).
Regarding your cap comments - I also initially liked Silmic. It has a pleasant, smooth signature. But on more critical listening, especially rich, well-recorded classical music, I found that its weakness is not just resolution. It's actually poor response to micro-transients in general. This affects the reproduction of attack phase (en.wikipedia.org/wiki/Timbre#Envelope) and ultimately leads to a sound that is smooth, but never really true to life...
Os-Con in C916 does not "flatter" the sound, but I do think its tonality is largely correct. It is much more likeable when used with Starget in the PSU - Starget warms up the overall presentation, making it more "natural" and less "neutral".
If you find Os-Con thin and hard sounding, then I do think you would like the combination of Starget + Os-Con in the PSU, in conjunction with another Starget in C916. You can buy Stargets on eBay, or from me - send me a PM if you are interested.
Regarding Duelund caps - I was actually entertaining the thought of buying one 0.01uF Alexander cap for comparison in C906... Expensive, but it will be interesting to see how it stacks up against my hand-made VNM Cap. Another cap I was considering was Jupiter HT Beeswax. Similar price to the Alexander, but I don't really want to buy both... anyone wants to lend me one for testing? :P
Old 21st November 2011, 07:35 AM   #5124
Default Spdif Output
Attached is the output from my Shigaclone
Any faults with the waves?
How can the quality be improved?
0.5v/Div
0.1us/Div
Old 21st November 2011, 02:29 PM   #5125
hi,
out of interest, could you please tell me if you have made any mods to the board.
Old 21st November 2011, 06:05 PM   #5126
Hi changed some things. I did some of the okapi stuff and as Peter changed c908 into a Wima and c939 and c929 into oscons, and changed the c916 to nichicon fg 49/10. Psu still nichicon FG 2200 and cerafine 1000uf (this will be changed to oscon). C906 still csr tftf 0.047uf. Shinkohs still in place. I must say this config improved it. I can't compare with black gates and kinda gave up finding them. I think next improvement will be some changes on my dac. Would still love to have the 300r naked vishay. Found the caddock in dk.
Old 22nd November 2011, 11:11 AM   #5127
Tham is offline Tham  Malaysia
Originally Posted by aparatusonitus View Post
Look better, pins 6/22/62 are feed from pin 11/IC903 (regulator +5VDC output), so all supply for IC902 is +5VDC. So for start you can carefully lift pins 6/22/62 from pcb, connect them together in one single point, and inject +5VDC from regulator of your choice. But, remember two things:
1) you should prevent IC902 from latch-up, meaning IC902 should not be powered up before IC901 wich send digital signals to IC902...you see, first supply signal then power up, that's how you prevent from latch-up. Find post from ilimzn at digital section about latch-up, and all will become clear how to deal with it.
I am thinking of giving this a try but am unsure of the "latch-up" arrangement. I will use the std 7808 supply and a separate +5V for the pins indicated. Do I need to power up the +5V section (with a separate switch) after the +8V?
Any help will be appreciated.
Old 22nd November 2011, 02:48 PM   #5128
Originally Posted by j baldam View Post
hi,
No mods done
What's your interpretation of the waves
Old 22nd November 2011, 02:55 PM   #5129
Hi sorry not an expert but others who are now know that it is a standard player.
I for one would be interested in comparing before and after mods.
Old 22nd November 2011, 03:36 PM   #5130
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Attached pic shows how to connect separate 5 V supply; no "latch-up" arrangements are needed.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Copyright 1999-2017 diyAudio
