| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#501 | |
I think you're right. Just to be clear, in the diagram here : http://www.airlinktransformers.com/t...ing.asp?data=4 the black and yellow wires are tied together to form the CT. Cheers, Dennis |
#502 |
I don't have a capacitance meter unfortunately - think I'll get one from Ebay. Sounds like a useful device to have. All the caps have been used before (once) in other projects and they were fine then. I was very careful removing them so I assume they are still OK now.
I've had this with Black Gates before though and then just as I'm about to remove them they quite often come on song! I'll give it a week and then change the crystal back. If there's no improvement it can only be one of the replaced capacitors. Thanks for that link Dennis ![]() I think I need to take a crash course in how transformers work. Still confused. When I tried out my 16v transformer Peter said it might be too much for the LM7808 regulator, unless I used a LARGE heatsink. However, using this transformer 2 x 12v (a recommended configuration for this project), surely the regulator will have to then deal with 24 volts then? Or have I got this all wrong? |
#503 |
Johnm. If you have 2 pairs of secondary's,you can join the two inner wires to make a CT,but I beleive that you will get 24v on the two outer wires. Check it with a meter.
If all you need is 12v ac just use one pair of the secondary's |
#504 | |
from Wikipedia: "Full-wave rectification converts both polarities of the input waveform to DC(direct current), and is more efficient. However, in a circuit with a non-center tapped transformer, four diodes are required instead of the one needed for half-wave rectification. This is due to each output polarity requiring two rectifiers each, for example, one for when AC terminal 'X' is positive and one for when AC terminal 'Y' is positive. The other DC output requires exactly the same, resulting in four individual junctions (See semiconductors, diode). Four rectifiers arranged this way are called a diode bridge or bridge rectifier:" A full-wave rectifier converts the whole of the input waveform to one of constant polarity (positive or negative) at its output by reversing the negative (or positive) portions of the alternating current waveform. The positive (or negative) portions thus combine with the reversed negative (or positive) portions to produce an entirely positive (or negative) voltage/current waveform. For single-phase AC, if the transformer is center-tapped, then two diodes back-to-back (i.e. anodes-to-anode or cathode-to-cathode) form a full-wave rectifier (in this case, the voltage is half of that for the non-tapped bridge circuit above, and the diagram voltages are not to scale). Note: The last parathetical sentence applies to you
#505 |
Thanks for that
I'm going to print that up!So that means I am using 12v then - cool. It's slowly seeping into the old gray matter ![]() Much appreciated! |
#506 |
Johnm. The photo below shows a dual secondary tranny. One pair of the ac sec's is connected to one bridge and the other set of ac secondary's to the other bridge. The Bridge Rects are marked + & -, these are the dc outs. the terminals in the opppsite corners are connected together to provide the 0v voltage ref
http://i73.photobucket.com/albums/i2.../DualBRect.jpg In the second picture I use a CT tapped tranny and only one Br Rect. This is simpler in that the two dc outs are marked +& - and the ac goes to the other two. The CT is connected to direct to the power ground. http://i73.photobucket.com/albums/i2...BridgeRect.jpg |
#507 |
Hi got mine up and running today -will allow burning in-unable to get GB from OZ and M Percy is not responding
So far upgrade power supply with full bridge rectifier-Mundorf power cap all caps are replaced with Rubycon ZA/ZL/ZLG series dig out-75R/75R So far so good. |
#508 |
Sorry had to delete last post with pix and schematic as I noted a couple of schematic errors, and also want to post the pictures so that they are comprehensible. Will try next week. Sorry..
Anyone who download schematic please delete.
www.kta-hifi.net |
#509 |
Thanks Puffin / Kevin
![]() I'm clear now - I'll twist together the two wires in the 'center' for the CT, and - as Peter said - this will go directly to the negative of the first PSU cap. The 'outer' 0v and 12v on the transformer will goto both AC points on Peter's PSU board. I will be using the PSU board with only two diodes as shown in earlier pics. Thanks, - John P.S. Just to avid confusion, both the JVC and the 16v torroidal I used were both single secondaries only, and for those I used four diodes. For this new dual secondary (2 x 12V) transformer I just use two - correct? |
#510 | |
diodes are require. Dennis P.S. You guys are really quick on this project; I've had the boombox for a week and haven't even taken it apart yet.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Jode |
| Page generated in 0.13620 seconds (65.24% PHP - 34.76% MySQL) with 11 queries |
