| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#5071 |
Hi !
I mean I soldered a wire on the cristal metal case ( be careful do not exceed 4 sec to avoid cristal damage) to connect it to the ground. It's better to avoid parasitic capacitor... So I have a " 3 leg cristal ". |
#5072 |
Hi Nomdi.
What crystal and what groundpoint did you use? Brgds |
#5073 |
Hi !
I use this one http://item.mobileweb.ebay.fr/viewit...d=400231819515 This is standard cristal. I simply used the central pin ground connection of the stock oscillator. Rgds Last edited by Nomdi; 27th October 2011 at 07:50 AM. |
#5074 |
I think Peter mentioned something much earlier in the thread about using a couple of twists of wire to add a little capacitance....
So just to be clear.... you soldered one side of each cap to the crystal body, and the other side to the 2 outside pads on the board? Fran |
#5075 |
Yes that's it !
And the cristal body becomes the central pin as with the ceramic resonator. Sorry I forgot to take a picture... |
#5076 |
Finally the picture ! sorry for confusion...
Cheers !
#5077 |
Hi, apoligies if this has been answered but it's a long thread and I've read most of it and Peters condensed version.
I have the parts from an EZ51 which has a different display pcb. There are 3 grey wires and 1 orange entering a plug marked led led sync sync. with a legend saying it goes to the main board. Could anyone please say what I do to these wires, if anything ![]() I don't need to cut down the board.
#5078 |
Hi J Baldam.
It looks just as mine. I cut the 2 rightmost ones down and the grey nmbr2 goes thru a pot to tha lowest connectorpin on the flatcable connector. I took the orange one to the left/most downwards connector of SW706 ( the most right/most downwards switch (repeat?)) Brgds |
#5079 |
Hi, thanks for the reply,
Right I discard the 2 right grey wires. I connect the remaining grey to the lowest pin on the outside connector row. The orange goes to the repeat switch. Think I've got it but the grey through a pot ![]() and could you please tell me why this has to be done ![]() cheers |
#5080 |
I have a potentiometer so I can decide how bright the led should shine - 1K in series. Well, pot and pot - there are kinds for different occations I guess
