Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th August 2011, 09:01 AM   #5021
johnm is offline johnm  United Kingdom
johnm's Avatar
Originally Posted by CeeVee View Post
don't dispair...tons availaibel:
SF-P101N | eBay
Those are the ones with the magnetic hub - the one's we're talking about have the 3xball bearing method of attaching the CD to the hub.
Old 1st September 2011, 07:03 PM   #5022
I tried the vref generator circuit, this is how I have it connected. Once connected my shigaclone stopped working. My meter shows 2.5v at the ZMR25 reg output, which is good. But the "To vref" has a 5v reading. what am I doing wrong here?
Uploaded with ImageShack.us
Old 1st September 2011, 07:12 PM   #5023
Vincent check the connections on U1, the op-amp. It seems that you may have accidently connected the 5V Pre-reg source to the Output of U1?
Old 1st September 2011, 07:42 PM   #5024
I will double check when I get home unless Im looking at the wrong data sheet, I believe I have U1 connected correctly.
Old 2nd September 2011, 06:14 AM   #5025
I checked everything and I didnt find anything wrong. All the connections to U1 is corrected and no solder bridges. I even swapped in another 5534 and the results are the same. The output of U1 is 4.35v, the +V feeding U1 is 4.94v
Old 2nd September 2011, 02:56 PM   #5026
Vincent, is the INPUT voltage to the +pin (pin 3) of U1 at 2.5V? (NOT the power supply pin or voltage)?
Capcitor type for Vref
http://www.ti.com/lit/ds/slos070c/slos070c.pdf
Old 2nd September 2011, 04:21 PM   #5027
Yes pin 3 of U1 is 2.5v
Pin 6 is 4.35v
Old 2nd September 2011, 06:15 PM   #5028
I'm puzzled. I have built 4 of these JohnW regs and have not seen this. Please measure the dc voltage at every pin of 5534. Report here. I'll do the same.
Old 2nd September 2011, 09:22 PM   #5029
aparatusonitus's Avatar
Disconnect opamp output from C906, place some 1k and up from opamp output to ground, measure voltage at all opamp inputs and output (all should be at the same DC voltage 2V5).
Non é mai abbastanza...
Old 3rd September 2011, 04:37 AM   #5030
noSmoking's Avatar
hi,
I am going to build a PS for the shing to separate digi and anolog(motors) do you thing it would be benificial to make another to power vRef circuit?
Copyright ©1999-2013 diyAudio
