| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
Inside the chassis there are 3 spherical mill outs in which the poles fit loosely, allowing sideway movement.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#42 |
#43 |
As to transformer, I wouldn't recommend really small units and 50VA could probably be reasonable minimum.
I also have slight preference for 96VA Hammond EI over same type 50VA unit.
#44 | |
Well here in Sweden NetOnNet has it for about $65 but shipping overseas would't be cheep I guess
![]() Maybe one should buy one ![]() /T Quote:
#45 |
I can't see where the EZ31B has a Digital Out ? I have looked at the specs and cannnot see it. Is it that it is disabled for the Boombox ? Or not used and it is just a matter of connecting it up?
#46 |
It's only on the PCB and used in the actual boombox.
#47 | |
I have seen, heard, used the Shigaraki which is why I am going to build this clone. It's gonna be fun.. Thanks Peter for sharing this and all of the additional input you have provided to my many questions..
www.kta-hifi.net |
#48 |
In the U.K, shops have the EZ31 and the EZ31B. I see that Peter Daniel had stocked up on the EZ31B, but in this thread I see it is just referred to as the EZ31 ? Will either do ?
#49 |
B is for Black, over here only that model was available. EZ31 should be exactly the same, just silver.
#50 |
Puffin, please read the thread before posting.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| jazz35 |
| Page generated in 0.12341 seconds (65.28% PHP - 34.72% MySQL) with 11 queries |
