Finally, an affordable CD Transport: the Shigaclone story - Page 497 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th July 2011, 12:06 PM   #4961
uncle_leon's Avatar
@ syklab - The built-in DAC is not very good and you would be generally much better off building a proper DAC from scratch, than trying to mod a weak one in hopes of improving it.
@ debk - sent you a PM
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 6th July 2011, 03:14 PM   #4962
maartentje's Avatar
Why is everyone mounting the transport at 2points instead of 4?
Old 6th July 2011, 03:18 PM   #4963
It sounds better that way from what I understand...
"When the world is running down,
you make the best of what's still around."
Old 6th July 2011, 03:18 PM   #4964
syklab is offline syklab  Mongolia
Hi uncle_Leon,
I bought a AD1955 DAC board for the Shigaclone, since I had this tube buffer ripped out from my old Tjoeb 99 so I just want to find a way to make some use of it.
Thanks for your reply.
Old 6th July 2011, 07:41 PM   #4965
maartentje's Avatar
hmm interesting..
Old 6th July 2011, 08:29 PM   #4966
johnm is offline johnm  United Kingdom
johnm's Avatar
Hi folks!
Was wondering if anyone had tried playing about with the values before/after the LM7808 regulator? The Shigaclone standard seems to be 1000uF - regulator - 1000uF.
Was going through the LM7808 datasheet out of interest and it mentions you only need a 0.1uF cap (ceramic disc type recommended) after the regulator. Has anyone tried this?
http://www.national.com/ds/LM/LM340.pdf
Is 1000uF really needed before the regulator too? I'd be interested in people's views/experiences with this. I'm going to try a 0.1uF tantalum cap after the regulator on my Shiga and see if it makes any difference.
- John
Old 6th July 2011, 11:01 PM   #4967
uncle_leon's Avatar
@ maartenje - the original Shigaraki transport is mounted at two points; Peter's experiments (later confirmed by others) indicate that it really does make the transport sound better.
@ johnm - Without the big input cap you would be feeding the entire AC ripple into the regulator, which can't be a good thing... As for the output cap, I think you could get away with a small one, but only on condition that the regulator is installed directly at the load (which is not very practical).
Sound-wise, caps lower than 1000uf seem to result in bass loss.
Oh, and the "Shigaclone standard" is actually 2200uf - reg - 1000uf Although 1000-r-1000 works just as well most of the time. Capacitor types are more important here than exact values.
Old 8th July 2011, 12:43 PM   #4968
johnm's Avatar
Uncle_leon: Thanks for the explanation - I understand the need for the 1000uF (or higher) for the 'input' cap, but I don't see what could cause bass loss with using less than that at the output of the regulator, particularly when the datasheet recommends 0.1uf. As my Shigaclone is in a Peter Daniel chassis, the regulator is right next to the transport mech. I guess in this instance then I could safely experiment with smaller value caps?
Was wondering if there are any fake Sanyo transports doing the rounds out there? The first transport I took from a JVC boombox had Sanyo clearly embossed in the moulded black plastic housing which the laser is mounted in. A mechanism I got from another JVC didn't have any logo embossed into the plastic, and ditto for two Sanyo spares which I got from Ebay (and which were advertised as genuine Sanyo spare parts). Is there anyway to tell if one has the real item or not?
- John
Old 9th July 2011, 03:43 PM   #4969
I got it together and working!
Uploaded with ImageShack.us
Old 9th July 2011, 04:57 PM   #4970
hotiron is offline hotiron  Scotland
hotiron's Avatar
That looks totally WICKED!!
How about swapping those bolts out for some stainless cap bolts.
(We call them Allen Screws over here.)
If you give up easily Dont start!!
Copyright 1999-2017 diyAudio
