Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story - Page 494 - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th June 2011, 12:31 PM   #4931
woood09 is offline woood09  Netherlands
Hi apoopoo999
It looks very good.
Have fun.
Woood09
Old 11th June 2011, 01:38 PM   #4932
apoopoo999 is offline apoopoo999  United States
Originally Posted by Dr.H View Post
Stunning mate! Any guidelines for someone hoping to do something similar?
Size and thickness of Aluminum slab?
Where did you have it cut, etc.
The aluminum is 2" thick, here is a copy of the template I sent to the machine shop
Old 11th June 2011, 02:33 PM   #4933
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi apoopoo999,
Very very nice, maby is this some inspiration for the display?
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 11th June 2011, 06:18 PM   #4934
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Here is the picture for thickness alumunium slab
Good Luck
Old 11th June 2011, 10:19 PM   #4935
BMW850's Avatar
Originally Posted by Erik van Voorst View Post
Hi Rudy
I am waiting for your pictures of platform/puck in action.
I reckon you also do no longer post on the dutch htforum like I use to do...
Erik
Hi Erik,
I've just created a few photos and it looks pretty good I say so myself.
It strikes me now that there are many CDs that are not purely flat.
Of topic:
Spent today with my DDDAC to build in 7 Sallas regulator, connected to 1 Transformer 2x12 volt 500VA.
The problem is when I connect 3 Sallas regulator to the DDDAC receiver board I blow up the diodes on the minus side from 1 Sallas regulator
2 Sallas regulator works good, after that I connect the third Sallas regulator to another 12 volt transformer and everything works fine.
And I must say the sound is realy good with only 3 Sallas regs on the receiver board.
What is the reason why the diodes blows up from the third one, who giveís the right answer to me?
Sallas told me there is no problem to connect 7 Sallas regulator to 1 Transformer
That I no longer write on the Dutch forum is because there are no Shigaclone builders anymore
Rudy
Edit: more fotos
Old 11th June 2011, 11:03 PM   #4936
BMW850's Avatar
2 more pictures 1 with a bottle what I need now
And the other one how I connect the DDDAC with the 3 Sallas regulator.
The + 12volt DC is not connected.
Rudy
Old 12th June 2011, 11:21 AM   #4937
BMW850's Avatar
This is the final definitive schematic of the Salas regulator.
I hope this is the right one, I ask in the other thread the schematic and I get this one.
I hope somebody can help me to connect all the Sallas regs to the DDDAC to use 1 Transformer.
Rudy
Old 12th June 2011, 08:06 PM   #4938
Hi rudy,
I saw the drawing of the regulator, and there isn't an op-amp in the circuit. Use a Sulzer or a Walt Jung reg,
make some by yourself, they are easy to bult, cheap,stable and very good. I have no doubt that they are better then the one on the drawing.
I have good results with the Sulzer regs, and the circuits
are free to download on the Walt Jung site.
Give it a try!!
Woood09
Old 14th June 2011, 03:46 AM   #4939
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Hi:
Not sure where you got that regulator schematic, but it shows DC in, not AC. I think the diodes you are blowing are not on the schematic, so it is hard to diagnose why they are blowing. Also, the schematic you posted has sense connections which you do not show on your earlier wiring diagram; do your Salas reg boards have sense connections?
Anyway, if you are blowing the rectifier diodes then you are puling too much current through them. This would imply that the regulator is shorted to ground. I don't know anything about the circuit you are connecting to, but you should double-check your connections. You should also fuse your transformer primary so you blow a cheap fuse instead of rectifiers or other components.
Old 14th June 2011, 03:51 AM   #4940
nezbleu's Avatar
Originally Posted by woood09 View Post
Hi rudy,
The presence or absence of an op-amp is irrelevant to the performance of a regulator. Some very good Jung-style series voltage regulators use op-amps as error amps. The Salas regulator design is a shunt regulator, and does not use an op-amp, but it performs very well indeed.
The problem here is not one of regulator performance. The problem is he is blowing up the (rectifier?) diodes in his regulator. This suggests the regulator is hooked up incorrectly, and a Jung/Sulzer regulator will perform no better under such circumstances.
[/QUOTE]
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
Copyright ©1999-2017 diyAudio
