| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#4891 |
trace it to a point and connect it there, look for transistor 412 ,you got a schematic?
#4892 |
it's on ic 701
#4893 |
Can't upload the manual go google it JVC RC EZ31.
Good luck, |
#4894 |
#4895 | |
Peter, After you removed the choke L901, do you have to put 2 jumper wire there to reconnect the trace line? Thanks |
#4896 |
Are you seriously saying that you ran a "regulator" circuit with no power to the error amp??? If so, it wasn't regulating anything, and any voltage you measured on the output was coming from somewhere else.
#4897 |
Yes nezbleu, embarrasingly, that is exactly what happened.
Try it, measure it, listen to it, post results here...plus an explanation for what is happening. I'm not sure. |
#4898 |
This would make more sense both wires twisted and connected at the same point as close to vref as possible.
If you give up easily Dont start!! |
#4899 |
I would agree. It would certainly be more in line with the normal application note for op-amps.
Still, I measured 2.5Vout without the Vss and Vcc being supplied to the op-amp. In addition, I was able to adjust this output voltage (at pin 6 of the op-amp) through adjsuting the pot connected to the LM317 I was using. |
#4900 |
Hi. How much of the transport should stick up from under the case?
Does anyone have a template for the CD cutout? I'm almost done, just have to finish the top cover (and fix a trace). |
