Finally, an affordable CD Transport: the Shigaclone story - Page 479 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th May 2011, 10:01 PM   #4781
uncle_leon's Avatar
Originally Posted by Manolo47 View Post
It suddenly stopped working.
Symptoms:
The disc when first placed starts to rotate, but counterclockwise, and never recognizes the tracks.
When it stops, it displays 99 99 00 and does not recognize the TOC command nor any other.
Checked the Power supply it is Ok. Disconnected and connected the ribbon connectors, etc.. they seem ok
Do you think it might be the laser assembly or the electronics in the board?
Sounds like it might be a problem with the motor controlling chip, the one with little heatsink - it's a dreadful suggestion, but perhaps it overheated at some point?...
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 7th May 2011, 03:09 AM   #4782
Default I tacked it to a knicked powe supply cable...
nt
Old 7th May 2011, 10:53 AM   #4783
c12mech is offline c12mech  United States
c12mech's Avatar
Always seems to be the simplest things that cause the most headache.
I'm hoping today to get my stuff mounted on some kind of board. I'm still waiting on the Mouser order for all the parts to make it work but if I see it on the board that will make me happy for now.
Old 7th May 2011, 06:18 PM   #4784
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Originally Posted by Magura456 View Post
At your service
Hi Magura
did you compare the original crystal with trichord no 4 before ?
what is your summary
Old 8th May 2011, 03:51 AM   #4785
c12mech's Avatar
What have you people done to me?
I decided tonight to plug in try out the transport in its untouched state. I made up some patch cables at work today and hooked everything up using the boombox as the PS and the audio out pins to my headphone amp. I mounted to transport on a piece of 1.5" thick poplar that I had laying around and just let the display lay beside it. Everything worked as it should have. I pulled out a couple of cd's that I have listened to religiously for years and heard things that I never knew were there. I thought it must just be my mind playing tricks on me so I hooked up to the computer where I have the same music ripped as flacs. The stuff coming out of the computer sounded utterly lifeless. I could not believe it. And this from the stock board with no changes. I really can't wait now to get all the parts and have this thing setup properly.
Old 8th May 2011, 01:41 PM   #4786
hotiron is offline hotiron  Scotland
hotiron's Avatar
Guys I am selling one of my donors EZ51H Brand new in the box. JVC RC-EZ51H Shigacone donor Finally | eBay UK
If you give up easily Dont start!!
Old 8th May 2011, 03:21 PM   #4787
hotiron's Avatar
Default Even better Still
NEW JVC RC-EZ51H Portable CD Player | eBay UK
Chewing my own *** off here but these are like hens teeth. eg Scarce!
I'm Not sure how he can post for 4.99 It cost me 6.80 to post a pair of crossovers the other day!
Old 8th May 2011, 03:53 PM   #4788
Pocoyo's Avatar
Hi
Has someone compared result of "original crystal & 5v input VS Trichord no 4" ?
Please share the result
Thank you, best regards
Old 8th May 2011, 06:01 PM   #4789
Pocoyo's Avatar
Originally Posted by Pocoyo View Post
Hi
Has someone compared result "original crystal & 5v input VS Trichord no4" ?
From PAGE #321 POST#3210
Originally Posted by audiojoy View Post
I added the trichord clock 4 needs burning in,but at the moment prefer the stock clock for its more natural warmth of tone. Strings have a smoothness and fullness with the original clock, but sound a little more detailed and harsher with the Trichord. The Trichord provides a little more air but not necessarily more presence and realism ......... need to burn the clock 4 in before making more judgements.
however the biggest improvement and it was the same regardless of which clock i used, was adding my own diy bybees. Brought solidity and tangible presence to voices, almost as if i was closer to the microphone now and more able to hear the details in Frankies voice. Not a huge jump but certainly a more significant upgrade.
PS as i had blown up so many transports i got fed up of upgrading the caps and so these comments are made on a stock version with no cap upgrades.
Photos to come at the weekend.
From PAGE #322 POST#3211
I added the trichord clock 4 needs burning in,but at the moment prefer the stock clock for its more natural warmth of tone. Strings have a smoothness and fullness with the original clock, but sound a little more detailed and harsher with the Trichord. The Trichord provides a little more air but not necessarily more presence and realism .........need to
Used the pioneer stable platter disc and yes preferred it to the ebony. same naturalness and presence but less loss of detail and not as overpowering in the midbass,which felt unnatural overall to my ears. Perhaps because it was more correctly centered? ...
EUREUKA !
Hmmm ! Natural vs Detailed .....
Erik used BG for clock supply ...
Original caps still on the board .
Maybe i know the answer what i must to do now
"The second mods" & "Salas Shunt +5V Supply with BG Caps"
Get a sound like TL0 is more than enough for me now
Old 8th May 2011, 11:16 PM   #4790
I can't believe it...
I've just come in and checked the final price of the EZ51 that was on E Bay.
I did NOT bid because I was expecting ' you lot ' to drive it up to stupid levels and found it went for 30 ish delivered.....I want to type loads of rude words here but I know I can't.
I even said to my wife ' I should put 40 quid on this to see what happens but someone will pay double probably '
Holy schmolly - wish I'd stayed in...
Copyright 1999-2017 diyAudio
