Finally, an affordable CD Transport: the Shigaclone story - Page 455 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th March 2011, 10:01 PM   #4541
Originally Posted by woodturner-fran View Post
I installed an awslr tonight in my second shiga. I think theres an improvement - maybe slightly more resolution and separation. Its not huge mind you......
Fran
Hello Fran did you use also the caps before and after the awslr like BMW850?
and also separate transformer for the 5 volt .
I will try the awslr tomorrow.
Can you give me some more info how you do it?
Old 26th March 2011, 10:16 PM   #4542
The awslr is fed by a cap-7812 -cap, nothing after the reg. Haven't done a separate 5v yet...... but the pics of how to wire it in is back a page or 2
Old 26th March 2011, 11:03 PM   #4543
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Fran, I think you should try 5V regulator without any pre-regulation. If AWSLR won't do it, find something else. I'm pretty sure that 12V 3-pin regulator is "masking" purity of a good discreet 5V regulation stage.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Old 26th March 2011, 11:09 PM   #4544
As it is right now the awslr is supplying the 8v to the whole player. It's easy to remove the 7812 - I'll try to get to it tomorrow....
Old 26th March 2011, 11:11 PM   #4545
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi Fran,
Peter is right, you should try AWSLR 5V regulator without any pre-regulation.
Rudy
Its not what you know, but who you know and where they are
Old 26th March 2011, 11:28 PM   #4546
Do you guys mean feed the awslr directly from the diodes? Or do you put a crc just before the awslr?
Old 26th March 2011, 11:48 PM   #4547
uncle_leon's Avatar
I would imagine the latter (with crc) - can't see any regulator being very happy having to deal with high AC ripple
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 27th March 2011, 08:13 AM   #4548
Erik van Voorst's Avatar
Originally Posted by BMW850 View Post
Hello Fran,
Every little bit helps to improve the Shigaclone.
I have first a 1000uF FK Black gate then ALWSR then 1000uF STD Black gate.
You also have a Trichord Clock 4 to try, you will be amazed?
Rudy
Hi Rudy,
Did you experiment with a Blackgate "Afterwards" since ALWSR themselves advices to use no caps at all afterwards...
(ALWSR Manual 3.0 WARNING AND CAUTIONS...THEY TALK ABOUT INSTABILITY)
The 8V and 5V regulators came in 2 days ago....so...
BTW
I see you using a puck...how did the puck-story end ???
To baldly go where no man has gone before................(James Kirk)
Old 27th March 2011, 08:52 AM   #4549
Hi Fran,
Rudy
Is that not depending on what configuration you use on the ALWSR board.?
Rudy do you use tracking pre regulation on the ALWSR board or not...
I do not think it is wise to use no pre regulation at all (see also their manual) in this case.
Old 27th March 2011, 09:18 AM   #4550
hello Fran and you must also bypass the 5 volt regulator on the board
now you use use 3 regulators in a row with the best in the middle .
Copyright 1999-2017 diyAudio
