| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#4291 |
Hi guys, thanks for all the great work; my transport sounds fabulous in standard config.
A few questions: 1. What does C916, C906 and C952 decouple? 2. Why is C952 removed and not replaced? 3. Anyone tried Pete Goudreau's triplets in these positions? 4. Anyone tried OSCON's? 5. herewegoagain has posted pics showing that the spdif output is not rellay improved through reclocking, but that the use of a 300/100 ohm output squares it nicely. Is this consistent with listening tests? 6. Any other caps worth replacing? 7. Any thoughts on the best mechanical approach for the transport? I was going to do an over the top heavy base, but is that the best? 8. Any benefit in using ALW or Teddyregs? 9. Any benefit in using an accurate clock like Guido's etc? Thanks for any pointers. Ryan |
#4292 |
You can find service manual here: http://www.ferdsaudio.com/RC-EZ31.pdf
The most critical mods have been described here: The CD Transport I tried Goudreau triplets some 10years ago, but don't do that anymore as my priorities have changed: The mods never end, adding Goudreau's triplets My CEC TL0 uses mostly Oscons and sounds great, so it might be good idea try them here as well. I don't use reclocking any longer, critical listening tests indicated that reclocking was actually degrading sound (into more digitized character). I actually converted my TL0 and friend's TL1 from output reclocking into 300/100 output with positive results. I tried ALW in some other circuit and wasn't impressed much, my preferred regulator for digital is presently this one: Finally, an affordable CD Transport: the Shigaclone story (courtesy of Bobken) I tried Tent clock in both CEC TL0 and Shigaclone, and never liked it. I got similar results with two other transports whenever Tent clock was used. I still share Romy's opinion on clocks: GoodSoundClub - Romy the Cat's Audio Site - The clock upgrades: my proposals
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC Last edited by Peter Daniel; 25th February 2011 at 06:41 AM. |
#4293 |
Hi Dr H
As shiga talk in the first time by okapi or PD - removed caps cause it was found degrade the sound - few builders were tried with oscon but the issue was the brand of the capacitor here - Okapi tell us to change bgn/x 47uf, 2x33uf, 2x10uf & 0.1uf - Eric reported change bgnx 0.1uf to mundorf silver in oil 0.01uf - PD reported just change bgn 47uf 50v has a good sound - Eric said that ALWSR better than LM7808 - A few people reported that tricord no 4 was the best for shiga It will be back to your taste and budget, best regards Btw if you search for BGF 1000uf 35v I will sell it for US$ 20 I got nichicon fx too 1000uf 63v @ us$ 3 |
#4294 |
Excellent Peter, thanks!
Any comments on the best mechanical approach to the transport. I thought a very heavy base/enclosure would work? Last edited by Dr.H; 25th February 2011 at 06:58 AM. |
#4295 |
This approach works very well for me:The CD Transport
It is heavy copper base, mechanism mounted on two standoffs only, wood trim and acrylic top for pleasing appearance mostly
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4296 |
Thanks Pocoyo, Daniel.
So C906 is the magic cap in the shigaclone. Has anyone tried to replace or remove its bypass, C908? Also, is there any sound benefit in fitteing a seperate 5V regulator in additiopn to the 8V supply (i.e. seperate the supplies)? Last edited by Dr.H; 25th February 2011 at 02:23 PM. |
#4297 | |
Non é mai abbastanza... |
#4298 | |
There is certainly possibility of a gain with separate 5V regulator, although LM317 I tried wasn't an improvement. I'm presently working on a different set of mods, including discreet 5V regulator. I should be able to test it soon.
#4299 |
oops, you're right on C908. what is the function of the pin that c906 is connected to?
#4300 |
Peter, you never stop, do you?
![]() You already have what is arguably one of the best CD transports in existence, but that doesn't stop you from trying to make an even better one... And best of all, after doing all the hard work, you come here and give the design for free to anyone who has sense enough to listen to your advice. It never ceases to amaze me.
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." Last edited by uncle_leon; 25th February 2011 at 05:51 PM. |
