Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 4th February 2011, 01:13 PM   #4221
uncle_leon is offline uncle_leon  Poland
uncle_leon's Avatar
I would love a custom-colored puck, but... considering most people spent less than 150 euro on their entire Shigaclone I think the price really is too much. It is too much for me anyway...
If it was around 50 euro I would probably go for it - not so much because of the sonic difference (which is said to be minor) as for the cool looks . 150 though... I'd rather simply spray-paint my plastic puck and forget about it...
How do you guys get your plastic pucks balanced by the way? Mine has a circular magnet at the centre that's kind of loose fitting - I want to glue it in place, but don't know how to balance it properly... Any suggestions?
Old 4th February 2011, 01:37 PM   #4222
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
You don't need to glue the magnet, just centre it properly and tighten the screw. That should fix balance problems to certain degree. Some pucs seem to be slightly better than the other.
To order kits contact me through forum mail.
Old 4th February 2011, 02:39 PM   #4223
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Please listen without magnet.
Make something without that it wobbles and it must be stable , and remove as first the magnet.
We have multiple people are listening and they found it all sound better without magnet.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 4th February 2011, 02:56 PM   #4224
There are some comments from 47Labs dealer here:
http://www.diyaudio.com/forums/digit...ml#post1189723
http://www.diyaudio.com/forums/digit...ml#post1330555
Personally, I don't find those differences mind blowing and value convenience more. OTOH, if I would be building an ultimate transport, I would certainly install those custom pucs
Old 4th February 2011, 04:11 PM   #4225
EUVL is offline EUVL  Europe
150 Euros for two turned parts based on a sketch with no mechanical tolerances ?
Old 4th February 2011, 04:44 PM   #4226
The main requirement is matching of the motor shaft to the disc table. That can be done on spot, with motor supplied to the fabricator.
However, how this turns out in real life, when disk is spinning, can be only assessed in a working transport. This is a tricky part and I don't think it can be done without trial by error
Old 4th February 2011, 06:58 PM   #4227
BMW850's Avatar
This is the machine: YouTube - CNC machining of a small demo vise made of brass
Old 4th February 2011, 11:21 PM   #4228
DaveM is offline DaveM  United States
DaveM's Avatar
Nice machine, but tolerances should still be specified. If you don't he may not ream the shaft hole but simply drill it. This may or may not yield acceptable results. Tiny tools tend to flex. A drill could wander so you want to use a boring bar. With a boring bar you need would likely need to use a pin set to sneak up on the diameter. Using a reamer would ensure that the diameter is spot on.
Old 5th February 2011, 08:32 AM   #4229
BMW850's Avatar
Everyone thanks for thinking I have these comments all discussed with the owner of the company.
Also things here on the forum is discussed with the owner again thank for this
This is a professional company and I assume that there are no tolerances in the CD Platform.
Of course there will be a couple tests first done , so no tolerances in the Cd Platform comes also ensures that the price on the high side.
If this company would not be able to make this platform where else would I have to make it.
Rudy
Old 5th February 2011, 08:37 AM   #4230
There is no mechanical component in this world that does not have a dimensional and/or geometrical tolerance, whether it is manufactured by a 1 million Euro CNC machine in Germany, or by a manually operated machine in India. As long as there is no tolerance on the drawing, then it is free tolerance, which is commonly in Europe +/-0.25mm.
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
