Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 5th January 2011, 05:08 PM   #4171
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
Originally Posted by BMW850 View Post
How do you all think about it?
It is an absolute requirement that CD platform is machined with platform mounted on a shaft, otherwise you will get wobbling problems. For that reason, it's advisable to machine the parts from relatively soft material, like Delrin or acrylic.
The whole batch of Delrin platforms that is shown in your attachment was screwed up and not possible to use only because the shaft holes were drilled last.
To order kits contact me through forum mail.
Old 5th January 2011, 06:02 PM   #4172
woodturner-fran is offline woodturner-fran  Ireland
I understood that 47 labs mount the platform on the shiga spindle and then have a little attachment that takes a final shave off the mount and puck so that its centered accurately.
Fran
Old 5th January 2011, 06:07 PM   #4173
DaveM is offline DaveM  United States
DaveM's Avatar
I believe that issue can be eliminated if the critical diameters are cut in the same setup as the bore. It will take a bit more material to do it that way, but you should be able to do it.
1) setup stock in a collet
2) drill, bore then ream the shaft hole
3) turn bottom side features
4) turn the top side mating face and center hub ( where disk locates)
5) turn the part around in the collet
6) finish top side features ( thread etc.)
Old 5th January 2011, 06:13 PM   #4174
kevinkr's Avatar
Yeah I have one of those.. It was also so slippery that I had trouble tightening and loosening the puck..It wobbled badly. The wood one with brass threaded insert I have now works pretty well, a bit hard to get on and off in winter, but otherwise fine.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th January 2011, 06:35 PM   #4175
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Thank you all for the answers and help, I tell the company about the things you all write here.
The last 2 pictures for the screw puck is the right one I think, you all see here also the pictures how I make the Shigaclone: http://www.htforum.nl/yabbse/index.php?topic=86768.450
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 5th January 2011, 07:21 PM   #4176
highfidelity is offline highfidelity  Germany
Wow, which is that for a display?
Many regards,
Matthias
HP: one can a 7-segment LED display in place of the LCD insert?
Have someone an idea to concerning the wiring
Old 5th January 2011, 08:15 PM   #4177
BMW850's Avatar
Ask Peter Daniel he knows
Old 5th January 2011, 09:01 PM   #4178
It's a CD Pro with a display board Brian GT designed for his school project (limited functionality though).
Old 5th January 2011, 09:09 PM   #4179
Harolda is offline Harolda  Netherlands
Interesting topic,
but the JVC drives are probably not available anymore?
regards,
Old 5th January 2011, 09:30 PM   #4180
tube 300 is offline tube 300  Netherlands
Originally Posted by Harolda View Post
Interesting topic,
regards,
Hello Harolda yes they are still available
and if you like to hear such a transport your welkom .
ik woon in Echt
15 minuten rijden voor jou
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
