Good job with the boards Oleg! Will you be sharing the gerbers or selling the boards? I have several broken Shigas, I might be able to salvage the chips from them or from the EZ31 I just bought if I had a new pcb. I think it would be great for the community if there was a way to build more of them. Do you happen to know a reliable source for the chips? I've bought some from Aliexpress, from vendors who have sold me genuine obsolete transistors in the past. As far as I know there is no easy way to test if they are counterfeits.
Good day
I find chips in our old service shop
About 20 years ago this guys working and repair the many audio equipment
How about Ali
I don’t know maybe this is remarked different crystals maybe not
How about Ali
About boards
I think the best way a find the complete boards from iTiberius
Because cost if you build that with many parts at himself is very highly
Buy boards
Buy chips
Buy resistors and capasitors
Buy crystal clock
Buy display
And more and more
Working donor some like jvc 31 is low cost for build this project
Buy boards
Buy chips
Buy crystal clock
Buy display
And more and more
What channel did you obtain this type of PCB from? I know what this is.PCB boards a first version with two mods
Good day
I reading posts about mods in this forum and Poland forum
After that I draw first version of ShigaClone and added two mods on board
You don’t have this design because I draw this at himself
I am looking for the exact model naming of the associated SANYO mechanism for pick up (laser) units as follow:
1) SF-P101 (here I have found only various versions from SANYO's DA series e. g. "DA11V" - go to datasheet under
https://www.tradeeasy.com/home/aceltd/425678/DA11VZ.pdf
and DA11T3C - no datasheet to find - only mentioned under
https://www.classic-serviceparts.com/(S(wxshwp32jvcicvermhurtm1x))/Download/20170110_laser.)
2) SF-P1 (no information)
3) SF-90 (no information)
4) SF-91 (no information)
Unfortunately the Vasiltech overview don't mention this - only the types of optical pick up is to find.
Maybe one of the members know this.
On the mechanism, which is to replace there is no sticker for reading the model resp. type No (like to observe on SONY mechanism from KSL/KSM series for KSS laser units).
Thanks for any advice.
Maybe with help of all datasheets one get an answer to the question under
https://www.diyaudio.com/community/...sf90-cross-compatibility.383531/#post-7678301
The label on the PCB shows that this is a free PCB manufacturing service provided by this factory, including free shipping fees within China. I'm curious about how you, a Russian, got this kind of service? It seems that you are very good at finding parts and services in China.PCB boards a first version with two mods
Same heads
2) SF-P1 (без информации) - plastic case
3) SF-90 (без информации) - metal case
4) SF-91 (без информации) - metal case with connector
This is old versions of SF-P101
His used in CEC2100/3100/5100 and more old CDs
That wayThe label on the PCB shows that this is a free PCB manufacturing service provided by this factory, including free shipping fees within China. I'm curious about how you, a Russian, got this kind of service? It seems that you are very good at finding parts and services in China.
Dear TiefbassuebertrI am looking for the exact model naming of the associated SANYO mechanism for pick up (laser) units as follow:
Please attach photo of your head and mechanism
I haven't laser heads and mechanism, but nevertheless I want to have the datasheets of often used mechanism. In the attachment some images of SANYO's mechanism for SF-P101N, SF-P1, SF-90 and SF-91.
I think my version of design is not original ShigaClone 2012
Wow wow wow…
I get this one main design from Europe forum
Maybe this is middle version between Shiga2012 and ShigaMKII ?
Wow wow wow…
Good dayYou may try to replace c906 with a good 100nF MKP.
Does laser fire-up at TOC reading ?
Tibi
Dear iTiberius
You my New Hope
Maybe you have the schematic for this board project ?
Because is labels R/C/L and smd stabs is not same with Shiga2012
Please mail me in private
I would like to buy a display for Shigaclone by Tibi MKI or MKII, white LCD, if anyone has it and doesn't need it, please send me a message.
You may also want to look around for a boombox donor, they still crop up occasionally. The old LCDs were strictly superior to the Tibi remake (even though he did a great job, it was a titanic effort to even make it work as just suitable parts were no longer manufactured at that point). But the originals did have much better viewing angles (also in my private opinion their backlight was a nicer colour, better for night listening).
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
