Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th April 2008, 03:23 PM   #391
johnm is offline johnm  United Kingdom
johnm's Avatar
I'm using an Antex 25W iron with a 'pencil' tip, and using solder wick.
The other iron I use for large jobs is a Weller 60W job.
I think my close-run incident with the lifted solder pad was just because I was having difficulty unsoldering those SMT capacitors. I've been a bit wary of unsoldering items on the board since...
At some point I will need to get a temperature controlled iron I think... along with a new PSU transformer, a custom built aluminium case for the Shigaclone, a new pair of speakers etc etc etc
- John
Old 15th April 2008, 03:30 PM   #392
Badge is offline Badge  United States
I am late to the party as usual. Are any of the current offered JVC's using the same components?
The freaks stick together, they are a tight old crew
Old 15th April 2008, 04:02 PM   #393
kevinkr's Avatar
No... Your choice is limited to the RCEZ31 or if you are up for a major challenge the RCEZ32 which is still obtainable in the US.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 15th April 2008, 04:23 PM   #394
johnm's Avatar
I think the RC-EZ51H was mentioned as a replacement (near start of this thread) that would work?
- John
Old 15th April 2008, 04:30 PM   #395
Vladco is offline Vladco  United States
Kevin where are you able to find RCEZ32?
I'm not able to find anything.
Vlad
Old 15th April 2008, 04:33 PM   #396
johnm's Avatar
Wee question: are those Citizen crystals directional? Peter I noticed you'd taken the metal covering off of yours... any benefits?
Old 15th April 2008, 04:37 PM   #397
kevinkr's Avatar
Vlad
I may have cornered the supply, but they have been available on eBay up until now. So far I have bought 3.. (One was stolen, one had an experimental accident late the other night, and now the controller may be permanently dead, and another one is on its way.)
When working the RCEZ32 based solution can sound very good. I was pretty impressed after the last round of mods. I will share more details once I know that the thing is actually working again and my mods aren't the cause of the controller problems I am having. (I don't think they are - I can think of two unrelated things I did that might account for the issues.)
Old 15th April 2008, 04:48 PM   #398
kevinkr's Avatar
Hi John,
They aren't directional, and it looks to me like Peter slipped some heat shrink tubing over the metal cylinder that houses the crystal. Removing the housing will probably destroy the crystal. I installed mine without the tubing. (Didn't have any of a small enough diameter, and I am not all that crazy about thermally "distressing" the crystal with my heat gun anyway.)
Old 15th April 2008, 04:52 PM   #399
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I put some soft padding over crystal and secured it with heatshrink. To me it seems like a bit of improvement, but I can't be completely sure about it
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 15th April 2008, 06:36 PM   #400
johnm's Avatar
I read somewhere that it's good to keep the crystal as free from vibrations as possible so it certainly wouldn't have hurt - I'm going to glue gun mine to the circuit board.
Peter - probably a simple question... for an expert - but where do I put links on your PSU board for the 12v dc to get to the main board? I've followed Otapi's DIY PDF to the letter, but I think he left out the bit about needing to jumper from the small board to the big.
- John
Copyright ©1999-2013 diyAudio
