Here is the schematic I am currently working on. It also works without changes with LM317.
Guys I have to say... The impact in the sound was really big. Everything is more "right there". Bass is a bit shy still, but I expect it to come back as the caps break in.
Oh and the transport... The smoothest, fastest and most silent movement I have seen on the shiga so far...
Dimitri ,wich capacitor you use in 2200uF position? Pana FR ?
Yes FR
By the way, I tried the tracking preregulator today.
Here is a photo
And here is the schematic.
I built the load reg exactly like my previous schematic, and just added the input prereg LM117.
Input and output caps are the same. Voltage reference stuff are the same. For C2+R I used a sprague 10uF capacitor.
The result was a vastly smoother sound. Everything seems to flow out of the space in the room, and highs are WAY clearer. With the LM117 itself I was thinking that the Muse 1000uF was too dark, but now I really like where this is going...
In the photo I have not included the reference capacitor. Again I used 220uF panasonic FR.
Tommorrow I will build a 5V one and power V1 and V2.
I just have to remember to buy some nylon screws because the insulators I got for the TO-3 were wrong.
Here is a photo
I used a cheap 10uF electrolytic for both of them. This needs to NOT be low ESR. If you do not have anything low ESR, just use a 1uF with a 3R3 or a 0.1uF with a 10R.
The most important part is still the led reference on the second reg. This makes more than half the difference.
By the way, for the led reference cap it might be a good idea to use a polymer electrolytic. Like Sanyo Oscon or Nichicon CK for their ultra low ESR (7mOhms vs 190mOhms for the FR). I will get some with my next order.
The difference in the output impedance should be devastating making the psu much better...
For those who do not follow Shiga MKII construction thread.
Just to bring in attention latest modification.
http://www.diyaudio.com/forums/digi...kii-black-builders-thread-21.html#post3948117
Modification was implemented and tested on Shiga MKII and brings substantial sonic improvement.
Detailed info in mentioned thread.
Tibi
Tibi
Nope you got it in the wrong place. The leds replace R4 and you put in parallel to them a low ESR 220uF electrolytic.
C2 and the purple R can be both replaced by one cheap NON low ESR 10uF capacitor.
I will post the complete schematic later today when I get home from work
that would be nice,thanksNope you got it in the wrong place. The leds replace R4 and you put in parallel to them a low ESR 220uF electrolytic.
There you go
The important bits are:
C3 is NOT low ESR
C2 IS low ESR
C4 is NOT low ESR
Also note that since I am running a big cable I also added a big filter cap right on the diodes, effectively creating a small CLC with the input capacitor and the long wire. This does not significantly affect the character of C1, especially if it is low ESR which means that more or less it will dominate the supply with its speed.
I tried a CRC but it significantly affected the sound adversely and the reference leds blinked just a tiny bit during big power pulls (speed up or breaking for example)
Anyway, as you can see in my scope view there really is no need for further filtering.
By the way, the prereg with this reference seems to give 8.25V output. This is quite ok as it seems, since my shiga is working perfectly for days now, and I think Tibi had said that you can use a bit higher voltage with just a bit more heat on the bridge chip.
Anyway, If you still want to get it to a straight 8V, the recipe is
2 red leds, 2 IR leds and one 1N4002
Thank you,dimkasta
The formula for reference voltage is the same?
I've worked for small board with 3 smd leds and two byw27 diodes and forward voltage for the board is 6,67V.
6,67+1,25=7,92V
Hope that is OK
6,67+1,25=7,92V
Hope that is OK
Yes the formula is the same.
It should be ok but Tibi should verify this.. The transport worked with even 5V. I learned this the hard way mixing my 7808 with a 7805.
By the way, did you measure it in circuit, or with a random battery and resistor? The forward voltage drop increases a bit with current, so I would try it in circuit with a dummy load of about 10ohms. If it is still below 8V, you can try using a bit smaller R1 to increase the current through the leds, although, 5mA is their sweet spot for minimum noise.
LA6541 will work fine between 5.6V and 13V. However above 9V a heatsink is required for both LA6541 and 2SB764.
Tibi
I haven't been looking at this thread for a year or two and am amazed just how far the original Shigaclone (EZ31) has evolved with the Shiga MK2.
Is there a thread/site that has kept up with the tweaks/upgrades for a stock EZ31 unit? I have found Uncle Leon's web pages at Studio Zèy. Would this be the latest updated info on mods (including the MK2 tweaks/upgrades where applicable) for the original Shigalone (EZ31)?
Marcus,
You want to read Shiga MKII construction thread. It is still readable.
http://www.diyaudio.com/forums/digital-source/255887-shigaclone-mkii-black-builders-thread.html
And here is one modification who made me name it "WOOOOW effect" which can be implemented to any EZXX:
Tibi
- Digital Source
- Finally, an affordable CD Transport: the Shigaclone story
