Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th February 2010, 12:34 PM   #3901
Excellent! Thanks to all.
I'll let you know how I get on
Old 5th February 2010, 12:43 PM   #3902
Default more easy re-clocking
i got busy with MS paint and annotated another pic - should make it a bit clearer.
Graeme
Old 5th February 2010, 12:59 PM   #3903
Originally Posted by herewegoagain View Post
This circuit really does seem to 'get everything in order' before it leaves the player - which IME translates into music that is - dare I say it? - more ordered(!), more tangible and more realistic.
After a couple of hours of listening, I agree with you. The first impression I got was a cleaner sound, more defined and it was confirmed track after track. Nothing extraordinary, but noticeable. It's always difficult to judge when you already know that something has changed, you can easily hear what you're expecting, real or not. But I'm quite sure that bass frequencies are improved, not in extension, but they're tighter and faster. Voices are very good and improved in clarity. I'm not satisfied with high frequencies. They seems to be more shrilling. I've a system in this moment that suffers in the high registry due to Aikido preamp in the making and I've noticed something worst in sibilants and cymbals for example. But with my previous commercial pre the highs were too soft, so I can't really judge it, maybe they're right now.
Old 5th February 2010, 01:03 PM   #3904
Massimo - actually the highs on my Shiga were a bit over the top when I first connected this up - after a while things calmed down - my de-coupling caps were brand new so took a while to burn in - remember they are across the important +5v supply in the player so some swapping might be needed once burned in.
are your caps new maybe?
Graeme
Old 5th February 2010, 01:39 PM   #3905
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
herewego...
You are being such a great help.
I find the text difficult to read in the MS paint rendering.
Could you enlarge the script size?
Old 5th February 2010, 01:49 PM   #3906
I understand. I didn't think about it. I'll judge it again in a few days.
new
Old 5th February 2010, 02:23 PM   #3907
Originally Posted by Ed LaFontaine View Post
herewego...
Ed - you should be able to read it if you enlarge the pic fully by clicking on the bottom LH corner - after the first click - in the icon thingy.
Graeme
Old 5th February 2010, 03:40 PM   #3908
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I'm just wondering if there is a cd door switch that I can salvage from the JVC boombox ?
I'll replace it eventually, I just want to get it up and running first.
Old 5th February 2010, 03:50 PM   #3909
Merlin, yes there is. Its a normally closed type if you are salvaging from something else.
The one from the JVC is in the door frame, has 2 wires that go back to a white push on connector that connects to the pcb under the mech.
I think its around the corner from the where the power supply goes in.
Fran
Old 5th February 2010, 06:59 PM   #3910
Ok, thanks. I'll pull it out of the boombox.
Where is that (i think 4.7uf ) bypass capacitor supposed to go?
Thanks,
JG
Copyright ©1999-2013 diyAudio
