Finally, an affordable CD Transport: the Shigaclone story - Page 384 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th January 2010, 06:53 PM   #3831
ddanbo is offline ddanbo  Canada
Saw them recently at Visions Canada as well!
http://www2.visions.ca/Catalogue/Cat...?categoryId=79
Old 26th January 2010, 08:11 PM   #3832
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Just a quick question here;
Where does a clock circuit fit in? Is it part of the transport or part of the dac?
I've built a couple of battery operated "monica" dacs (without any clock installed) - just a digital in.
I'm building an ezdac as well (hopefully) and it has a clock in the circuit.
Just curious that's all.
Old 26th January 2010, 08:19 PM   #3833
OneyedK is offline OneyedK  Belgium
Can be both, normally DAC will slave to transport clock.
But designs where transport slaves to DAC clock are also possible.
Old 29th January 2010, 05:08 PM   #3834
I picked up my jvc rc-ez31b @ the source.
Old 29th January 2010, 10:27 PM   #3835
I've got the transport out of the rc-ez31.
How do you pull the display out of the unit?
I've got a hammond 43va 12.6 vct (It's got 2 6.3 secondaries @ 3.4a) just wondering if it should be ok?
Old 29th January 2010, 10:34 PM   #3836
Never mind, I got the display out.
Old 31st January 2010, 06:14 PM   #3837
Originally Posted by Tony X View Post
When I bought a spare mechanism, it came with a small pcb just containing an end of travel limit switch and a connection socket.
I took mine off and replaced it with the main standard board and forgot about it. Then I saw somewhere an image of the main board separated from the mechanism and strung out like a trampoline to one side.
I did not see any comments as to whether this has any positive effects, (replacing the main board by a much lighter one - not the trampoline) but seen as how the shigaclone is so sensitive to mechanical mounting I would not be surprised.
Anybody like to comment? I am too lazy to take it all apart and remount it just to try.
Yes, I think it is worth separating electronics from mech for better details and opportunity to tune the sound by placing the el. board on various supports(carbon rods,wood etc.).The best in my chain it sounded with carbon placed on parafin table.Try it ,just have to solder 6 wires from board to board.Much better this way in my case.With Shiga you can tune the sound in so many ways ,what is the best part of the project.It remind my to analog turntable time ,endless bettering. By the way ,how to easy upload the photos with the post(always too big the photo size).
Old 31st January 2010, 07:04 PM   #3838
I've got R3, R4 & R5 out so far. I going to order some parts for the power supply.
How is the digital out taken from the board?
Thanks,
JG
Old 31st January 2010, 08:32 PM   #3839
Copper sheet metal 6in x 12in x .025 thick 22 gauge - eBay (item 110462990027 end time Feb-25-10 07:47:03 PST)
Hey, found a copper metal sheet on ebay. Just have to polish up a bit.
Old 31st January 2010, 10:40 PM   #3840
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The thickness of this copper is only good for lamination (0.025"). For double the price you can get same size plate and 10 times the thickness from local Metal Supermarkets store.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Copyright ©1999-2017 diyAudio
