Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 1st December 2009, 08:02 PM   #3721
robertor is offline robertor  Hungary
robertor's Avatar
Can you send me a link
no more on ebay.
there is now only the EZ-11.
rob
Old 1st December 2009, 08:27 PM   #3722
okapi is offline okapi  United States
okapi's Avatar
Originally Posted by Solve View Post
I have just bought an demo ez51 cheap and fired it up,just digital out.
But i have an crackling sound coming out and it doesnt matter what resistors i choose.
I have tried my Quatafire external sound card the Super Pro box.
Just crackling.
But if i connect it to Behringer DCX2496 it works and i have very high output.
The input sliders at almost zero.
So its very high output from the player,but i cant tame it and get rid of the crackles that
come one second and disappear next and come back.
Any suggestions?
I experienced similar symptoms when my ground connection for the digital output came unconnected. check your ground.
Old 1st December 2009, 09:53 PM   #3723
Solve is offline Solve  Sweden
Solve's Avatar
Thanks for the tip okapi but, it sounds very good true my DCX2496 so i dont think i have any grounding problem.But it accept the professional AES also.
Is it so sensitive to the resistors that i havent found right value yet?
Music is the only art in real time....
Old 1st December 2009, 10:57 PM   #3724
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
Originally Posted by tubo View Post
Peter,
My next job is to do the PS and the mods you currently recommend.
i just want to make sure that ill be doing the right things.
1. for PS. can i use elna silmicII (and or) nichicon KZ instead of BG? will BG be better?
2. remove R5 and E5 and choke. Or remove R1-R5, E5 and choke. is this also ok or leave R1-R4?
Is C952 the R5 and C916 the E5 on the pdf? if not what is it? where are the ceramic bypasses of C952 and C916 in the pdf?
BG will be probably better, but if you can't find them, use whatever else that works. Silmics have good opinion and are certainly worth a try.
To summarize my most recent mods, this is what I do:
I remove the choke and caps C916, C952
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st December 2009, 10:59 PM   #3725
I also remove ceramic bypasses for those two electrolytics, altogether 5 parts.
www.audiosector.com
Old 1st December 2009, 11:05 PM   #3726
I still use external supply as posted on a first page of this thread. Two wires from PS are connected to the pads where choke was.
I add two output resistors: 300/100 Dale (when building for myself, I use Vishay S102/Caddock) and in place of C916 I instal BG N, either 47/50 or 33/16 depending on availability.
That's all the mods I do presently, for more info see this link: Finally, an affordable CD Transport: the Shigaclone story
www.audiosector.com
Old 1st December 2009, 11:13 PM   #3727
feket663 is offline feket663  Hungary
Originally Posted by robertor View Post
no more on ebay.
In Hungary you can buy RC-EZ31 or RC-EZ51
ez31 here: Re-Carta Kft. JVC RC-EZ31, JVC RC EZ31, JVC ReCartaKft., RC EZ31 ReCartaKft. Divatos, hordozható CD rendszer, kazettás magnetofonnal, analóg AM/FM tunerrel és távvezérlővel 14990 Ft
ez51 here: JVC RC-EZ51 hordozható rádiós magnó - FotoMarket
price is about 50 Euro everyone.
Old 2nd December 2009, 02:02 PM   #3728
Tony X is offline Tony X  France
Tony X's Avatar
Peter
I removed bypass C917.
Is the other one this circled thing marked JW927 ?
I cannot find a C963 as per the circuit diagram.
I replaced C916 with an ELNA 47/22 which iw the closest I have.
Old 2nd December 2009, 02:23 PM   #3729
woodturner-fran is offline woodturner-fran  Ireland
No, I think C963 is the cap down and to the left of that JW927 - just at teh end of the big chip HWCAT...... see, if you look closely at your photo you can actually see C963 written on the silkscreen beside it....
Fran
Old 2nd December 2009, 02:27 PM   #3730
tiglitosa is offline tiglitosa  Greece
tiglitosa's Avatar
Send a message via MSN to tiglitosa
Fran
what a pair of eyes !!! try top gun exams !!
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
Copyright ©1999-2017 diyAudio
