Finally, an affordable CD Transport: the Shigaclone story - Page 352 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th July 2009, 06:47 AM   #3511
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
I have removed the wire from both of my units (31 and 32). I believe I traced it out to ground and my assumption was static protection on the original unit. Also removed the thin plastic, which was probably both protection and the source of the static on the original box.
Old 13th July 2009, 07:13 AM   #3512
Morfeus is offline Morfeus  Germany
this is exactly what the cable does. I wouldn't remove it.
Old 13th July 2009, 05:17 PM   #3513
Thanks for your help fellows! It makes alot of sense. I'll fill in with a thin foam spacer.
Guy
Old 17th July 2009, 10:45 AM   #3514
Default 5V
Hi ,
I need help...
I want to give separate 5 V to Shigaclone, but I do not know how to do exactly
Old 17th July 2009, 02:17 PM   #3515
Default Re: 5V
Originally posted by vitalica
Hi ,
I need help...
I believe Peter went through this in detail earlier in these posts. Search and you shall find.
Dan
Old 17th July 2009, 03:12 PM   #3516
Default Re: 5V
Hi ,
I need help...
Here's a hint, but you'll find way more answers if you do keyword search
http://www.diyaudio.com/forums/showt...58#post1759758
Old 18th July 2009, 08:46 AM   #3517
Hi Leoparleur ,
Je vous remercie beaucoup!!!
Thank you very very much!!!
Vitalie
Old 20th July 2009, 09:49 AM   #3518
Can I use a source of super stabilized 9V?
(Instead of 8V)
Thancks!
Old 20th July 2009, 10:14 AM   #3519
dzuvela is offline dzuvela  Croatia
(Instead of 8V)
Thancks!
9V is not recommended.
You can use 5V regulator and rise up output with zener diode 3V up to 3.3.V between middle leg and ground.
Old 20th July 2009, 10:33 AM   #3520
Thancks Dzuvela .
Copyright 1999-2017 diyAudio
