Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 19th June 2009, 08:58 PM   #3501
jeffr1966 is offline jeffr1966  United States
Default marketing
any chance Peter (or anyone) will be marketing this or something similar as a finished product or semi-built kit???
I am looking for a new transport of late but they are becoming fewer and farther between!
Jeff
Old 19th June 2009, 10:51 PM   #3502
audiojoy is offline audiojoy  United Kingdom
I think i will have another go with those surface mount caps in the power supply that i failed with before. feeling brave , but need to make advancements in this project as very little seems to have been accomplished since the original ideas were first advertised and no one appears to have tried the Piezobees!
Old 22nd June 2009, 05:40 PM   #3503
leoparleur is offline leoparleur  Canada
Originally posted by audiojoy
... and no one appears to have tried the Piezobees!
I will, but in a few weeks. I've ordered a few piezo models from digikey as different diameters and resonant frequencies. Anyways I needed a backup for my present accelerometer when measuring cabinets. Presently I'm starting the Shigaclone chassis, when finished I'll finalize sound tweaking, the piezo's will be part of it.
Old 26th June 2009, 05:37 PM   #3504
bikerboy is offline bikerboy  United States
Talking shigy mods
I mounted the shigy on a 4" thick mdf base and installed the crystal. I used 4 nylon spacers and brass screws. I mounted the tx in a second box. Sounds a lot better. Bass is tighter and symblence is reduced. Midrange is very sweet. I am going to use 4 wood blocks to mount the mech but the nylon spacers will have to do for now. Anyone have a remote control they can spare? Mine didnt come with one.
Old 27th June 2009, 12:29 PM   #3505
alexdiy is offline alexdiy  Thailand
Hi all,
I have some problem with my shigaclone , I using some month ago but now it control button is not work , the remote still work fine . I take a look at their schematic the button is connect to IC LC78601R , I already check the cable it is OK. My question is
1.Any possible that IC LC78601R failed in some function ?
2.If their failed whare can I buy IC LC78601R to replace it?
3.Any possible to modify CDROM controller that sale in Ebay to replace the control button , remote and display function?
Or any idea to check and fix this problem .
Thanks.
Old 5th July 2009, 08:29 AM   #3506
SteveSun is offline SteveSun  United States
Default Citizen Crystals
Hi Pete, may I ask a stupid question: why you choos the cylindrical type crystal instead of HC-49/U/... types, and what is the material that you wrapped on the crystal (thermo-insulator, shock absorber)?
Old 5th July 2009, 03:36 PM   #3507
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
The answer is simple: it was the only through hole part available from DigiKey. I used some soft rubber secured by heatshrink to wrap the crystal.
I don't change the crystal any more though, plays fine with the original resonator.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th July 2009, 12:28 AM   #3508
Hi Shigaclone is coming slowly.
Can someone explain me the use of this black cable and staple to the clear lens? Can I remove it, I'd like to put the display right against the rear of my stainless steel front panel?
Thanks,
Guy
Old 13th July 2009, 12:04 AM   #3509
kevinkr's Avatar
This is different than my version, (so I have no idea what that wire does, guessing it is part of the backlight circuit?) but I think you could mount the display against the panel without shorting this. It looks to me like it is lower than the display glass.
Be careful not to flex the ribbon excessively, an expensive lesson I learned the hard way.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th July 2009, 04:30 AM   #3510
Kevin,
Thanks for your input there. It must be part of the backlight or in some way the liquid crystal display, I have no knowledge there. The service manual does not show it either, unless I haven't understood the schematic correctly.
The wire, carton and staple are installed in front of the clear plastic layer so this adds 1/16". I'm hesitant to install it original since the staple being the first part in contact with my stainless steel front panel. Adding insulator like electrical tape will add thickness again and flex the clear layer excessively I guess or with time, it could detach from display. I'm taking your warning in consideration here. Thanks for that.
I would have liked to install the display directly to the back of my front panel but maybe I wont have choice to put dual sided tape in between. This would add depth to the display but I guess it would clear the problem.
Peter have you got an idea of the use of this wire?
Thanks guys!
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
