Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 13th April 2008, 09:17 AM   #311
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Hi Peter
Thanks for this interesting transport project!
I tried to order one yesterday and it seems, I found one online.
Let's look.
BTW: I did not find a translation machine from polish language to english.
Any hint?
Kind regards
Franz
Old 13th April 2008, 10:02 AM   #312
Franz Gysi's Avatar
Sorry, just google
A question: isn't it a disadvantage, to have a open drive?
No interferences / disturbance from the environment light?
Kind regards
Franz
Old 13th April 2008, 10:25 AM   #313
OneyedK is offline OneyedK  Belgium
We all listen in a dark room on sundaymorgings only (when the electricity is best for the real audiophile) ;-)))
No, seriously, you might have a point there, but as long as the light is rather constant (and it is most of the times) there will be no audible influence.
I worry most about the dust fallin' in...
Old 13th April 2008, 10:32 AM   #314
JeroenR is offline JeroenR  Netherlands
Perhaps a useful tip.....
I removed the display-connector but kept the leads. As I just want to use the remote and perhaps the buttons I wanted to get rid of the flat-cable. You can bend the connector upwards (some force) and cut of the sides, then fold the part without leads of the connector forward by sticking a screwdriver into the connector and twist. As the plastic is hard it will break of easily. Now you have a radiator like piece of plastic with the iron leads. Bend the leads up and again with a screwdriver wick out one by one the plastic strips. See picture for result. It should be easy now to add some wires.... if I can find out again what is pin 1...
Old 13th April 2008, 10:58 AM   #315
stefanobilliani is offline stefanobilliani  Italy
Originally posted by OneyedK
Sorry to quote this old post, but I calculated the resistors again.
Theoretically it should be 375 and 93.75 Ohm.
(you still woulld have to subtract the chips output impedance from the 375 Ohm)
That would give a perfect 75 Ohm output impedance, 1Vpp unloaded and 0.5Vpp loaded with 75 Ohm.
Any other value will render the coax into an antenna or ignore s/pdif specs. (and thus the receiver input)
That speaking out in terms of scheme is 375 in series at the output followed with a 93,7 in parallel ........ isnt like that ?
Well I guess that will work realiably if the chip output has enough power ...
Am I going to try a toslink ?
Old 13th April 2008, 11:28 AM   #316
Yeps, LC78601E uses 5V so at worst case output would still be 4Vpp (If output current is 12mA).
Chip output will have enough power.
/edit: Kevin, your 3.3V-assumption appears to be wrong.
I'll use a 93.1 Ohm as -what you call- the parallel-resistor and an adjustable 500 Ohm as series resistor. Measurement will show the exact value I need for the series resistor.
1Vpp unloaded output, 0.5Vpp loaded output.
Output impedance is more important than exact output voltage, so I won't worry if I end up with 1.2Vpp unloaded and 0.6Vpp loaded with 75 Ohm.
Toslink? In high end? Tsss... ;-)))
Old 13th April 2008, 11:38 AM   #317
Just to avoid confusion .
Old 13th April 2008, 11:49 AM   #318
Yeps, perfect...
And 375 = Zout + R1
Old 13th April 2008, 12:02 PM   #319
I guess the 12mA in the datasheet (LC78601E) aren't chosen for nothing.
So a recalculation with 12mA and 4Vpp chip output, gives
R1=291 Ohm and R2=100 Ohm to get 1Vpp unloaded and 0.5Vpp loaded with 75 Ohm.
I'll stick with these values. Kevin came prettty close, even starting from the wrong assumption.
Old 13th April 2008, 01:25 PM   #320
johnm is offline johnm  United Kingdom
johnm's Avatar
So does this mean that Peter's values of 2 x 75 ohms is maybe not a good idea then in practice?
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
Copyright ©1999-2017 diyAudio
