Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 12th April 2008, 09:15 AM   #281
johnm is offline johnm  United Kingdom
johnm's Avatar
Thanks for updating the PDF Okapi - looks great
- John
Old 12th April 2008, 01:57 PM   #282
kevinkr's Avatar
Here is a picture of the RCEZ32 electronics in operation
http://img443.imageshack.us/my.php?i...im00067xz5.jpg
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 12th April 2008, 03:39 PM   #283
stefanobilliani is offline stefanobilliani  Italy
Originally posted by kevinkr
This unit is box stock and the resistors I used for the spdif level reduction are quite dreadful.. The original values I chose are not the right ones for the amplitude I measured which was 5Vpp...
I must say in my tests yesterday I preferred to not have the parallel resistor after the series to ground . Guess why ? becouse the dac has its own 75ohm resistor in parallel at the input . That is at the other side of the cable . After some good listening I am going to choose a value for just series at the output that will vary from a min of 47 ohm to max 100 ohm . Will let you know .
Old 12th April 2008, 03:42 PM   #284
steenoe is offline steenoe  Denmark
steenoe's Avatar
In case anyone in Denmark wants one, SuperBrugsen, has them Just become a member and order one from "Nettorvet"
Here is mine, that I just picked up:
JVC There might be a good idea, in that thread too
Old 12th April 2008, 03:55 PM   #285
There seems to be too much un necessary stuff there .
I have been investigatin on the nature of the Motor drive Ic becouse I wanted to separate the supply of it , from the rest of the board ( I am planning to have a different supply for all the 3 ICs ) .
So my third mod was to have 2 supply . It is not very difficult do mod in that direction . I had a listening session with " steely dan -Aja " like never had before .
The ride cymbals on " black cow " are like planets floating out of the speakers , the sax on " aja " is so sweet and so well placed / non agressive in the scene that actually I was seeing it in front of me . The drum kit in " home at last " is fantastically present the bass drum finally sound like you can feel the tension of the skins . And it seems like sitting at least at the side of the drummer . Wow .
I am curious to know your impressions .
Just to let you know , I am using the DAC form Rockna , with the AD1856NK ( 18 bit ) ( thank you P D ) in non os mode . Eavily modified on the PS . That dac incorporates a reclocking circuit . I am a fan of " in sinc " connections when speaking of clocks (infact previously the dac shared the same clock of the dvd source ) , but in this test I am quite positively impressed and curious on what the freshness and dynamics ( which are very correct ) will give to the long term listen .
Old 12th April 2008, 03:59 PM   #286
johnm's Avatar
I've just got the main CD board out now and I'm going to be replacing some capacitors today or tomorrow.
However I just noticed that both motors are subject to a little 'rocking' movement if you wriggle them gently. I'm going to desolder them, and then make sure they're soldered down again firmly against the circuit board this time. Obviously as-is the spinning disc will create undesirable vibrations which isn't good.
I'll probably put some hot melt glue or blu-tac around the motor as well to further damp vibrations.
If I put my finger onto the cd hub, I can rock the motor left to right - there's about 0.8mm 'play' from side to side.
- John
Old 12th April 2008, 04:09 PM   #287
okapi is offline okapi  United States
okapi's Avatar
Originally posted by johnm
However I just noticed that the both motors are subject to a little 'rocking' movement if you wriggle them gently. I'm going to desolder them, and then make sure they're soldered down again firmly against the circuit board this time. Obviously as-is the spinning disc will create undesirable vibrations which isn't good.
- John
Hi John, the motor movement you are referring to occurs when they are screwed to the mechanism? if not, it might be possible that loose coupling between the motor and control board may reduce vibration transfer into the control board.
Kevinkr - thanks for posting the pics
Old 12th April 2008, 04:19 PM   #288
johnm's Avatar
Hi.
This is when it is unscrewed from the mechanism. I think you're right - that must afford a little bit of isolation from the circuit board I guess. I shall leave well alone
- John
Old 12th April 2008, 04:19 PM   #289
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
Yes indeed, I wouldn't worry about it. In fact, attaching them more securely to the boards may influence things in the wrong direction.
I tried to damp the transport frame too and it didn't work well.
To order kits contact me through forum mail.
Old 12th April 2008, 04:47 PM   #290
johnm's Avatar
Just a warning to those who have yet to de-solder the caps on the circuit board, those tracks can lift VERY easily. Be absolutely sure all solder is sucked up before wriggling those caps out. I lifted a solder pad but VERY luckily for me it was for a cap that was to be removed and not replaced anyway!
Peter I'll leave the transport undamped then - certainly a case of 'good vibrations'
- John
P.S. Regarding the motor 'vibes', would it be an idea to totally unsolder/decouple the motors from the lower curcuit board, so that they are only attached to the laser mechanism only by those four grub screws? This would allow the lower board to be mounted seperately to the laser mechanism...
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
