Finally, an affordable CD Transport: the Shigaclone story - Page 253 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th December 2008, 03:26 PM   #2521
kevinkr's Avatar
Originally posted by aparatusonitus
Hi valo,
I used to have the same problem...found a few wary tiny cracks in display PSB board as well as main board. Use a magnifying glass and light bending to see offending PCB traces, solder them and you'll be back in business.
This is very good advice, these boards are ROHS compliant and the solder connections do not handle flexing at all well. Look for connectors and components that have intermittent or open connections as well as possible cracks in the pcb. I have had problems with several of the connectors.
If you never over-voltaged the board the fact that you did not isolate the regulator tab from the heat sink should not have a bearing on the current problem you are seeing. Much more likely that some handling issue has occured. I assume you do take some rudimentary precautions against static electricity. (AKA ESD)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 15th December 2008, 03:35 PM   #2522
Erik van Voorst's Avatar
Valo
You really got me curious now.....are you saying that in your Post 2506 we can see an OPEN (modified) Forsell and a CLOSED Forsell....I find that hard to believe....
I do am very interested in the cap 1 Farad story...maybe you have the links where these pics come from...or maybe you can tell more about it since I do not see this as off-topic...
To baldly go where no man has gone before................(James Kirk)
Old 15th December 2008, 04:04 PM   #2523
valo is offline valo  Norway
valo's Avatar
Hi again
I have been looking for cracks but no luck and the connectors looks fine too, its sad it did sound werry well and i was just about to finish the project ... but i guess my regulator or static electricity did murder it ..
I did make my frame just like this one that Peter Daniel did , my regulator looks the same too but i dident use any isolation , so gnd on the reg has the same potensial as the mechanism
Anyway i did order two JVC RC-EZ51 today i got them verry verry cheap .. so i hope i learn from my mistake
Thanke for manny good tips
Old 15th December 2008, 04:16 PM   #2524
audio1st's Avatar
Hello valo.
If it spins up and reads "00", it is nearly always something to do with the white ribbon cable you can see in Peters picture, joins laser to the board..
Old 15th December 2008, 04:24 PM   #2525
valo's Avatar
Originally posted by Erik van Voorst
Valo
Its the same cdplayer, more pictures here in the norwegian forum hifisentralen
I dont know so mutch about this player all i know is that it was modifyed buy an Norvegian guy called Birger Lund maby he is in this forum ..
Old 15th December 2008, 05:45 PM   #2526
aparatusonitus's Avatar
Originally posted by valo
I have been looking for cracks but no luck and the connectors looks fine too, its sad it did sound werry well and i was just about to finish the project ... but i guess my regulator or static electricity did murder it...
Hi valo,
Before you dump it tell me one thing: when you hit the door switch in order to read the TOC, what is the output voltage of your regulator and for how long? If it is much lower then ~7VDC for few sec, it can't read TOC for sure, I've tried it.
Non mai abbastanza...
Old 15th December 2008, 06:36 PM   #2527
valo's Avatar
Hi valo,
Its drops from 8.01Vdc to 7.99 when i hit the door switch
Old 16th December 2008, 06:58 PM   #2528
Badge is offline Badge  United States
My unit is up and running. All that I need do is cut and install the top plate. The chassis is a two compartment box cast out of aluminum. It weighs 13 pounds. The rear compartment houses the power supply and the front has the transport. The display is separate from the chassis and mounted to the wood face. Wood sides and face are lace wood. Thanks to Peter and all here who helped.http://gallery.AudioAsylum.com/cgi/gi.mpl?u=4933&f=CDtransport.jpg
The freaks stick together, they are a tight old crew
Old 16th December 2008, 10:39 PM   #2529
kevinkr's Avatar
Can't load the picture link, it comes back as invalid even when I am logged into AA..
Edit: I did find it though - nice job, and a lot of really unusual pix in your gallery that I enjoyed checking out..
Old 16th December 2008, 10:47 PM   #2530
aaah, I tried to get in there too - go on, now I'm really interested.... please give us another link!
Fran
Copyright 1999-2017 diyAudio
