Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 14th December 2008, 08:30 AM   #2511
sparkle is offline sparkle
sparkle's Avatar
Originally posted by ccschua
Is it possible just to purchase the LCD panel as replacement ?
i doubt you will find the LCD panel .....
maybe if somebidy that allready used the transport, has some panel that he does not need.....
otherwise, i doubt it....
Old 14th December 2008, 08:43 AM   #2512
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
I would say no.
If you disconnect the ribbon is it still showing "38"?
Have you removed Q702? (you must if damaged).
Sorry to say you have most likely damaged a chip on the transport board.
The display should not prevent the transport from working.
Old 14th December 2008, 05:09 PM   #2513
valo is offline valo  Norway
valo's Avatar
think i did kill my transport today .. i did mount the regulator to the frame but i did forget to isolate if from the frame .. my transport canot find tracks on the cd anymore, the display onely show 00 now..
iam going to order an new jvc rc51 now..
iam thankful for anyhelp that can bring my board alive again
Old 14th December 2008, 05:31 PM   #2514
audio1st's Avatar
Hi valo,
The regs body is at 0V so should not have been a problem.
If you have unplugged the laser ribbon recheck it is connected correctly.
Old 14th December 2008, 05:34 PM   #2515
kevinkr's Avatar
Provided that you used an LM7808 regulator or one of its many variants the tab is at ground potential - more likely that you made some other error that resulted in an over-voltage to your board. (Like swapping the input and output pins on the regulator..) If you are sure you did not do this then you might want to check for other issues - I had the same problem when I did not have the mechanism ribbon fully seated.
Here is a link to the spec sheet for the Fairchild version of the part which shows very clearly what each pin is..
http://www.fairchildsemi.com/ds/LM/LM7808.pdf
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th December 2008, 05:47 PM   #2516
valo's Avatar
No , i have the rigth regulator an lm7808 and it gives me 8v, and everything did work just fine before i mounted the regulator on the frame..
Old 14th December 2008, 07:53 PM   #2517
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
.. my transport canot find tracks on the cd anymore, the display onely show 00 now...
Hi valo,
I used to have the same problem...found a few wary tiny cracks in display PSB board as well as main board. Use a magnifying glass and light bending to see offending PCB traces, solder them and you'll be back in business.
Non mai abbastanza...
Old 14th December 2008, 08:57 PM   #2518
valo's Avatar
Originally posted by aparatusonitus
Hi valo,
My display board is heavy modyfyed, just the connector left of it , but it did work just fine before i mounted the ergulator to the copper frame whit out isolating the regulator..
I did order a new JVC today so i shuld be back in business werry soon
Old 15th December 2008, 02:26 PM   #2519
scrutinizer is offline scrutinizer  Netherlands
I got the idea from this cdplayer, and this one is not an DIY player .. looks like a mess in ther but nice on the outside
anyway iam saving my big caps for an nie amp
Sorry for the offtopic on my part....
Valo your first picture has got nothing to do with Forsell's electronic layout and his CDM9 pro 'airdamped' mechanism
So I think this contrapsion must be a DIY
Anton.
Old 15th December 2008, 02:46 PM   #2520
valo's Avatar
Anton.
Thats rigth Anton, the first picture i did post here is my DIY cdplayer.. the modyfyed Forsell is not mine .. I onely wanted to show you guys the 1F cap that its inside it ..
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
