Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 27th November 2008, 05:34 PM   #2341
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Peter, you are the man This is a complete turnabout...
Old 27th November 2008, 05:37 PM   #2342
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
I'm not gonna hide that work was an inspiration too.
To order kits contact me through forum mail.
Old 27th November 2008, 06:08 PM   #2343
Puffin is offline Puffin  United Kingdom
Simple is often best. However as a result of laziness I never got around to housing my "shiggy"clone properly. It rests on an off-cut of Granite and sounds good enough to me.
Old 27th November 2008, 06:38 PM   #2344
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
I have been looking for a set of suitable springs for for ages, it was only yesterday I discovered a fantastic shop in Portsmouth that sells the correct size! (I didn't buy them)
Old 27th November 2008, 06:56 PM   #2345
Is that the Hampshire Spring Company?
Old 27th November 2008, 07:23 PM   #2346
Tripmaster's Avatar
Originally posted by Peter Daniel
I wouldn't be loosing sleep over all those additional mods and finding Black Gates.
I just put together another transport, the mechanism is mounted on standoffs to a bottom copper plate.
I only replaced PS, as descibed here: http://www.diyaudio.com/forums/showt...36#post1468036
Everything else, including resonator, is stock. The output resistors are 100/300R Mills.
The transport plays really good, as good as the original Shigaraki.
In some ways it is better that my prevous built, especially when it comes to raw energy in reproduced sound. The trade off is slightly less refinement and smoothness, but when you get used to it, you won't even notice
I will later post more pics of the inside job.
Nice sharp lines to your Shigaclone BTW
Old 27th November 2008, 07:56 PM   #2347
SCD is offline SCD  Canada
Peter:
Very nice work on the clone.
How about a few more pictures
SCD
Old 27th November 2008, 08:33 PM   #2348
While Eric pushes here the envelope of State of the Art, I tried to come with a simple solution that averybody can follow.
Let's start with PS. I used a circuit described here: http://www.diyaudio.com/forums/showt...36#post1468036
48VA Hammond transformer fits perfectly in a Hammond 1590T enclosure:
Diodes are mounted directly to connector socket:
and the whole thing came out quite elegant:
Old 27th November 2008, 08:37 PM   #2349
I was debating for days how to make it simple, yet nice looking. In the end I decided on a wooden frame mounted between two panels: frosted acrylic on top and copper on a bottom:
Old 27th November 2008, 08:43 PM   #2350
The PS is made on protoboard with 2 x BG STD 1000/25 caps. LM7808 regulator is attached directly to bottom panel. Two oversized brass standoffs support the mechanism:
Control switches are recycled from the original boombox; I used standoffs and protoboard to mount them:
I also implemented the original display board, slightly modyfing it to fit inside the chassis:
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
