Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th November 2008, 02:43 PM   #2331
tubee is offline tubee  Netherlands
tubee's Avatar
Ok thnx will ask them
Old 25th November 2008, 05:11 PM   #2332
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by m.massimo
A question about power supply.
I browsed the net to find information on LM78xx regulator (I've a technical background, but not on electronics). I found many schemes like the one in this thread (and that I made for my shigaclone).
In these schemes, cap before regulator is usually around 1000/2000uF, but cap after LM is from 0.1uF to 0.47uF (not 1000 uF).
For our application, is it more important quality, capacitance value or both?
Thanks.
It's quite common to use large caps after 78xx regulators, here's one such example: http://www.diyaudio.com/forums/showt...394#post942394
If you use very low cap value, the bass will be missing (in Shigaclone)
Another question.
I've a 80VA CT transformer in backorder from Digikey (the only items remained in back order). Now I'm using a 30VA CT. The transport works well. Do you suggest to maintain the 80VA back order and install it when it will be delivered (two months) or cancel it and stay with the 30VA? Thanks.
There is subtle difference between low power transformer and higher power, although I would say that in my system comparing 50VA vs 100VA was rather negligable.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th November 2008, 02:39 PM   #2333
valo is offline valo  Norway
valo's Avatar
Hi my frist post in this thread and hopeful not the last one
I did start on my trassport lastnigth after dismounting an EZ51H that i found in an local shop..
My powersupply is finished, Iam using an 2x12v/50va ulveco toroid BYV79 diodes and 2200uf/25 BG ,1000uf/25 BG and a 7808 reg.
My plan is to bild the transport as it is done in this pdf file http://tim.cheapo.cc/images/CD%20player%20mods.pdf. But i did run it to a small issue today, i cant find any parts use, i want black gates but i cant find them in norway, and the didital output resistors are not easy to find here .. so if anyone here has black gates and some resistors that i can use i will be verry happy to buy them
Iam alitle unsure what to do whit the oscillator change it or use a clock, guess i will use the stock one in the begining ..
Dont hate me for my bad spelling
Old 27th November 2008, 10:50 AM   #2334
Hi Valo,
If you want I have some resistors for Dout (metal film 1%) and one crystal to sell.
You have contact by email not activated. Please do it for a better communication.
Old 27th November 2008, 02:47 PM   #2335
Hi
I saw three type transport mounting.
What is better?
Is it better that Dout resistors stay on pcb or I can located on RCA?
Duka
Old 27th November 2008, 03:38 PM   #2336
I wouldn't be loosing sleep over all those additional mods and finding Black Gates.
I just put together another transport, the mechanism is mounted on standoffs to a bottom copper plate.
I only replaced PS, as descibed here: http://www.diyaudio.com/forums/showt...36#post1468036
Everything else, including resonator, is stock. The output resistors are 100/300R Mills.
The transport plays really good, as good as the original Shigaraki.
In some ways it is better that my prevous built, especially when it comes to raw energy in reproduced sound. The trade off is slightly less refinement and smoothness, but when you get used to it, you won't even notice
I will later post more pics of the inside job.
www.audiosector.com
Old 27th November 2008, 03:41 PM   #2337
This is how mechanism is mounted
www.audiosector.com
Old 27th November 2008, 04:16 PM   #2338
valo's Avatar
Massimo you got mail
Duka, I dont think it matter so mutch where you place the output resistors, i will mount them on the board.
Peter Thats an realy nice looking transport, did you mount the mechanism whit no damping/springs ?
Iam planing to use copper in my transport too, its a nice metal to work whit and i have alot of it too about 1 tonn
Old 27th November 2008, 04:22 PM   #2339
No damping and no springs.
www.audiosector.com
Old 27th November 2008, 04:45 PM   #2340
r8833 is offline r8833  Canada
Nice work Peter..great to see this thread back on the OT
Copyright ©1999-2013 diyAudio
