Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 13th November 2008, 04:38 PM   #2231
fraserh is offline fraserh  United Kingdom
Hi, i'm trying this out at the moment but have run into my first problems. I'm not 'modding' the player yet i simply want to run it as a transport to see how it sounds then go from there. So far i've taken it all apart and mounted the PSU board, the analogue board, the LCD and the transport onto some wood and it works perfect through the headphone jack so everything is still fine.
I tried taking signal from the DOUT and ground on the transport board into my DAC but i'm not getting any noise- and the headphone out still works. Is there something i need to disconnect before the digital out start to work?
How much of the stuff on the analogue board can i chop away? I only want the power to the LCD and the transport
Old 13th November 2008, 04:51 PM   #2232
r8833 is offline r8833  Canada
hi,
try page 2 post#28..really good guide..use 390/75r on s/pdif out..some people have reported without resistors ..signal will not lock on to dac
Old 13th November 2008, 06:31 PM   #2233
kevinkr's Avatar
Originally posted by r8833
hi,
That 75 ohm actually should be 93.1 ohms which in conjunction with 392 (1%) will give you very close to 75 ohm source impedance to match your spdif cable. These are the values I am using in my now 6 month old RC-EZ32 based version of the Shigaclone.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th November 2008, 12:05 PM   #2234
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
It is the turn of The Infamous Blue Led today..
Besides the tweak it is for me a very helpful light ''cause it shows exactly puck and platform in a see-through manner so I can easily mount and dismount the puck on the thread...
Out of a block ebony I make half a moon to follow the lines of the ...uhhh... turntable...
To baldly go where no man has gone before................(James Kirk)
Old 14th November 2008, 12:07 PM   #2235
After that I drilled a heavy copper tube with a 15 mm drill in order to make it adjustable in height and a passage for the led wires...
Old 14th November 2008, 12:08 PM   #2236
A hole for the led...drilled quite deep in order to get to the hollow tube...which can take care of the wires
Old 14th November 2008, 12:09 PM   #2237
As you can see it is adjustable in height and it can swivel sideways...
Old 14th November 2008, 12:11 PM   #2238
I could simply not resist to give it the look of the "cobra-arm"
Old 14th November 2008, 12:14 PM   #2239
...it is all still very loose on top of each other in order to make adjustments before the final fitting...but it gives an impression about the designfeatures.....I will mount it after a while......this way it gives me the chance of a second look....
Old 15th November 2008, 12:37 PM   #2240
I made the support and at the same time brushed the design a bit up...
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
